Created on: 25 Nov 2015 10:27
Koempy
I'll start right away.
Before March 2014:
After May 2015:
V3ctra15 Apr 2018 20:24
Now I’m sharing the current status of our house.
Construction site: Shell of a house with scaffolding, concrete blocks, and a crane in the background.
bortel
16 Apr 2018 05:51
Loads schrieb:
I was at the construction site today and was shocked to find that the heavy rain on Friday washed away the basement insulation. We were actually planning to backfill tomorrow. Looks like that won’t happen...
Why aren’t the light wells installed on top of the perimeter insulation? That creates a serious thermal bridge, doesn’t it?
V3ctra16 Apr 2018 06:17
bortel schrieb:
Why aren’t the light wells placed on the perimeter insulation?
That creates quite a thermal bridge, doesn’t it?
That’s right, in our case they were also fixed onto insulation boards.
Window opening in the concrete foundation with wooden frame, support braces, and protective foil.
Construction site with foundation slab, crane on the left, toilets on the right, unfinished buildings in the background.
77.willo16 Apr 2018 21:21
Same here
mertmk3
17 Apr 2018 07:46
I would have at least routed the conduits in the ceiling at right angles; as it is now, it’s a guessing game afterward where everything is—in case of any issues.
Today, the ground floor precast concrete slab is being installed. This evening and tomorrow, conduits will be laid again, and on Friday the slab will be poured. Next week, work can then continue with the upper floor.
ruppsn
17 Apr 2018 08:29
mertmk3 schrieb:
At least I would have routed the empty conduits in the ceiling at right angles...
Well, good luck pulling the cables through then [emoji6]
