mertmk3 schrieb:
Today, it's time to get started again! As I said, have fun!
mertmk3 schrieb:
At least I would have run the empty conduits in the ceiling at right angles; otherwise, it’s guesswork later on to figure out what is where—in case of need. I don’t know of any cables that can handle a zero bending radius, so such sharp bends are not allowed—you have to use curves instead.
Documentation never hurts, but nowadays as a proud homeowner, you’d usually do that by taking photos.
No idea where I wrote anything about kinking, but you can use 90° bends, even fairly tight with the thin cables, and then simply run them parallel to the walls instead of crisscrossing. Indoors, cables usually run vertically down within the walls, not diagonally across them.
there are good reasons to use the shortest route between two points for the cables. For cable lengths over 15m (50 feet) with 1.5mm² (approximately 1.5mm² or 16 AWG), you are no longer allowed to protect the circuit with 16A (16 amps). So it makes sense to keep the cable length below 15m (50 feet) by taking the shortest path.
Inside walls are done this way because it is required. There are so-called installation zones where the cables are allowed to be placed.
Knallkörper18 Apr 2018 13:39Tom1607 schrieb:
You are not allowed to protect a 1.5mm² (16AWG) cable with a 16A breaker if the cable length exceeds 15m (50 feet)!As an electrician, you can probably explain this more precisely? I would come to about 23 meters (75 feet), which is 50% more after all.
- Previous
- 1
- 2
- 3
- 10
- 20
- 30
- 40
- 50
- 60
- 70
- 80
- 90
- 100
- 110
- 120
- 130
- 140
- 150
- 160
- 170
- 180
- 190
- 200
- 210
- 220
- 230
- 240
- 250
- 260
- 270
- 280
- 290
- 300
- 310
- 320
- 330
- 340
- 350
- 360
- 369
- 370
- 371
- 372
- 373
- 374
- 375
- 376
- 377
- 378
- 379
- 380
- 390
- 400
- 410
- 420
- 430
- 440
- 450
- 460
- 470
- 480
- 490
- 500
- 510
- 520
- 530
- 540
- 550
- 560
- 570
- 580
- 590
- 600
- 610
- 620
- 630
- 640
- 650
- 660
- 670
- 680
- 690
- 700
- 710
- 720
- 730
- 740
- 750
- 760
- 770
- 780
- 790
- 800
- 810
- 820
- 830
- 840
- 850
- 860
- 870
- 880
- 890
- 900
- 910
- 920
- 930
- 940
- 950
- 960
- 970
- 980
- 990
- 1000
- 1010
- 1020
- 1030
- 1040
- 1050
- 1060
- 1070
- 1080
- 1090
- 1100
- 1110
- 1120
- 1130
- 1140
- 1150
- 1160
- 1170
- 1180
- 1190
- 1200
- 1210
- 1220
- 1230
- 1240
- 1250
- 1260
- 1270
- 1280
- 1290
- 1300
- 1310
- 1320
- 1330
- 1340
- 1350
- 1360
- 1370
- 1380
- 1390
- 1400
- 1410
- 1420
- 1430
- 1440
- 1450
- 1460
- 1470
- 1480
- 1490
- 1500
- 1510
- 1520
- 1530
- 1540
- 1550
- 1560
- 1570
- 1580
- 1590
- 1600
- 1610
- 1620
- 1630
- 1640
- 1650
- 1660
- 1670
- 1680
- 1690
- 1700
- 1710
- 1720
- 1730
- 1740
- 1750
- 1760
- 1770
- 1780
- 1790
- 1800
- 1810
- 1820
- 1830
- 1840
- 1850
- 1860
- 1870
- 1880
- 1890
- 1900
- 1910
- 1920
- 1930
- 1940
- 1950
- 1960
- 1970
- 1980
- 1981
- 1982
- 1983
- Next
