Created on: 25 Nov 2015 10:27
Koempy
I'll start right away.
Before March 2014:
After May 2015:
gmt94
9 Jan 2019 12:19
Work on the construction site continues tirelessly.
Despite modest weather conditions, the windows were installed yesterday, and the external insulation was started simultaneously.
Windows in red brick wall under scaffolding; view outside to trees and meadow.
Construction site view: open VEKA door frame in red brick wall; scaffolding and trees outside.
Construction site of a two-story house with scaffolding, timber framing, and outbuilding.
Two-story brick house under construction with scaffolding, construction site, and tree in foreground.
Two glass doors in the shell construction; VEKA packaging surrounding the frames, wood scraps on the right.
Today the roofer is sealing the base slab with bitumen.
Shell construction interior with red brick masonry, door openings, and construction tools.
Mottenhausen
9 Jan 2019 15:18
May I quickly ask what wall construction this is? 24cm (10 inches) brick plus 12cm (5 inches) external thermal insulation composite system (ETICS)? Sorry if I missed this information somewhere else!
haydee
9 Jan 2019 15:30
Note that the adhesive for the External Thermal Insulation Composite System (ETICS) requires a component temperature of at least 5°C (41°F), even at night. That is why our expert recommended starting the insulation work earlier.
pffreestyler
9 Jan 2019 16:01
The scaffolding has finally been removed at our place as well. Let's see how much brighter the joint will look now; up close, it still appears quite patchy.
Incomplete red brick house under construction with open window and door openings, construction container on the left.
gmt94
9 Jan 2019 16:25
Mottenhausen schrieb:
May I quickly ask what the wall construction is? 24cm (10 inches) brick plus 12cm (5 inches) external insulation? Sorry if I missed it somewhere else!
Yes, 24cm (10 inches) Poroton plus 12cm (5 inches) Rockwool.
haydee schrieb:
Be aware that the adhesive for the external insulation system requires a minimum substrate temperature of 5°C (41°F), even at night. That’s why our expert had the insulation work scheduled earlier.
Thanks for the tip about the temperature. They will continue on Friday, and it's expected to be warmer then.
blaupuma9 Jan 2019 19:26
pffreestyler schrieb:
The scaffolding has finally been removed at our place. Let’s see how much lighter the joint will get; up close, it still looks quite patchy.
Phew, I can hardly look at it—it really hurts the eyes.
I specifically chose a joint color that matches the cladding.
Open window in a brick facade; brick resting on the window sill, cable to the right.
