Created on: 11 Sep 2018 07:32
rick2018
Now a bit about me:
Greetings from Swabia
Modern villa with flat roofs, terraces, glass surfaces, green surroundings – several views.
rick201812 Jun 2020 20:52
I can upload a picture over the weekend.
The ceilings are installed on two floors. Partly, the lights, APs, and occupancy sensors are also installed. The color appears shifted due to the protective film on the glass.
rick201813 Jun 2020 06:00
Here are a few examples.
Unfinished interior with mint green walls, striped ceiling, and large windows.
Ceiling with parallel wooden slats; round recessed light, construction site visible behind glass.
Some built-in elements are still missing, but the recessed lights are installed.
The fixtures are Bega 55924 (3K) + Bega 10520. The pavilion is already equipped with the successor model 24234.
The fitness room and garage have Bega 55930 (3K) + Bega 10530.
Personally, I like recessed ceiling lights (if they are dimmable). In the dining area, there will be a pendant lamp (Louis Poulsen Artichoke, 84cm (33 inches), copper rose finish, DALI, 3000 K) installed.
In the living area, there will be a floor lamp (not chosen yet) and possibly additional lights on the sideboards. All lamps have 3000 K, so it’s a "warmer" light.
I had to order more LAN cables. I need to lay nearly 100 meters (330 feet) over the weekend.
Today, I’m first running six cables into the distribution board.
Several blue cable loops on a dark floor, some secured with yellow tape.
@superzapp Is CAT8 rated for 2000 MHz?
Bauherr am L
13 Jun 2020 08:38
@rick2018 CAT8, how many servers are in your data center?
Thanks for the photos and the information about the luminaires, very stylish. Is the Artichoke fitted with Dim2Warm? What about the spotlights? They have 3000K LED chips but no D2W, right? Are the spotlights adjustable?
rick201813 Jun 2020 10:19
@Bauherr am L those are just the cables to the control cabinet
This is how it currently looks inside the server cabinet. The rear side is still partially missing some components.
Network cabinet with many colorful Ethernet cables and server modules in the rack.
The Artichoke LED is only available in one version. I have to admit that I can’t tell you if it has D2W.
The spotlights definitely don’t have it. These are also not adjustable. We simulated the whole setup in DIALux (with our furniture). It’s meant to provide basic general lighting only. Additional lighting comes from floor lamps, etc. We also tested the spotlights beforehand. They are very pleasant. At least I don’t miss having D2W.
untergasse4313 Jun 2020 20:08
Bauherr am L schrieb:
@rick2018 sorry for the quick question: how did you implement the lighting control? KNX only or DALI? I think I read something about DALI earlier in the thread. Why did you choose that?
Thanks and good luck, it looks great. We are now at the shell construction stage...
Whether to use DALI or not depends on several factors. Beyond a certain number of dimmable lighting circuits or RGB applications, it simply becomes more cost-effective. Wiring is sometimes easier, as you just run 5x1.5mm² (about 10 AWG) cables and don’t have to worry as much about conductor sizes like you would with centrally supplied 24V lighting. Also, since it’s a bus system, you don’t need to wire the lighting circuits in a star topology (although you can with DALI if you prefer).
I find the setup and programming of lighting groups with many individual fixtures much more elegant with DALI than with pure KNX. One example would be larger cove or shadow gap lighting with many LED strips, which can be controlled much more evenly and easily using DALI. There are also “real” DALI lamps available, which can be nicely controlled that way. Ultimately, it also saves a lot of space in the distribution board since you don’t have to clutter everything with LED controllers (although you could do that with DALI as well if you want a central setup).
In a typical single-family home, DALI is less common because there usually aren’t that many lighting circuits.
rick201816 Jun 2020 14:20
Yesterday was a chaotic day... The photovoltaic system is still not connected to the grid, but at least we have electricity now.
The pool contractor, facade installer, and grinder have started their work.
This is what the poured asphalt looks like. So far, only the covers for the underground tanks have been ground.
These will be filled again and then finely sanded/polished. It will become darker and more intense.
At least now you can see the aggregate. Fortunately, there is more coarse aggregate than expected.
Six round granite grinding discs with holes in the middle on a light surface.
Close-up of a round concrete surface with pebbles in terrazzo style.
