Created on: 11 Sep 2018 07:32
rick2018
Now a bit about me:
Greetings from Swabia
Modern villa with flat roofs, terraces, glass surfaces, green surroundings – several views.
rick201824 Jun 2021 17:12
@schwalbe Thank you for your contribution and for taking the time to read through the entire thread. Sorry that you missed part of the action 😉 By definition, I am financially independent. That means I don’t have a regular job and I’m not employed anywhere. However, I do engage in regular activities that generate income directly or indirectly. My main tasks include shareholder duties within the company group, as well as managing (private) investments and monitoring them, among other things. I also need to take care of my mother. My days are very scheduled—actually, I have less “free time” than if I were working a typical 9-to-5 job. And that applies not only Monday through Friday. But I like it the way it is. Have you already started a thread for your renovation project?
schwalbe24 Jun 2021 17:27
Thanks for your reply. The game was really bad anyway, so I didn’t miss anything 😉
Yes, I have a thread running here, which should be renamed once the work begins. I’m thinking of sharing progress updates like you do, since other homeowners with similar experience might benefit from it. On the other hand, I’m probably a bit more "sensitive" than you and tend to be influenced more by others’ opinions, so this might not do me any favors. We’ll see…
Rumbi441
29 Sep 2021 08:35
I have a few technical questions for @rick2018.
Is mastic asphalt installed everywhere? How did you handle it on the bathroom wall? I don’t think tiles with grout joints match well with asphalt, so you probably used a different solution there. You don’t have to post a picture; just explaining the wall structure is enough.
You have a saltwater pool, right? Have you noticed any changes or stunted growth in the surrounding grass? Saltwater can affect the soil.
Regarding networking: What simple and cost-effective cable installation would you recommend if fiber optic cable comes from underground and you want to run five LAN sockets inside the house without KNX or other control systems?
rick201829 Sep 2021 08:46
@Rumbi441 the thread is huge, so you probably haven’t gone through all of it yet.
In the bathrooms, we have a seamless system from the company Dold. The joints between floor and wall are sealed with PU (polyurethane) sealant.
We don’t have a saltwater pool, but a chlorine pool. I also explained the reasons for this. The water flows into the overflow. Nothing reaches the lawn. A few splashes won’t harm the grass, whether it’s from chlorine, salt, or bromine—the concentration in a private pool is much too low for that. It just needs to be planned properly…
I don’t understand what you mean by the network. Do you have a fiber optic connection or fiber installed throughout the house? In the first case, simply use an all-in-one box, for example a FritzBox. Inside the house, cable with CAT7 or CAT8 cables. Please plan for one access point per floor.
Rumbi441
29 Sep 2021 09:02
Thank you for your quick replies. I must have misread that—260 pages is quite a lot! 🙂
Do you have an alternative or low-budget solution for the system from the company Dold? It seems too complex and expensive to me. Something along the lines of: screw OSB boards to the wall, seal the joints with paint X, and that’s it.
I only have a fiber optic connection and am now planning which cables need to go inside the wall—Cat7 and the Fritzbox will probably be sufficient.
rick201829 Sep 2021 09:05
There are certainly other manufacturers who offer such systems. Waterproofing is only necessary in the shower and possibly behind the washbasins. For the rest, for example, latex paint can be used. In the shower, materials like glass, aluminum, stone, etc., could also be used.
