Created on: 11 Sep 2018 07:32
rick2018
Now a bit about me:
Greetings from Swabia
Now a bit about me:
Harakiri schrieb:
@rick2018: Alright, that would be the option currently planned for us (of course without the Alucobond cladding, as plaster is also nice…).
Just out of curiosity, what insulation thickness and material did you choose? I am considering (if cavity insulation overall is too expensive) having both the below-grade and exposed surfaces insulated entirely with XPS.What advantages do you expect from using XPS instead of EPS on the facade?
@rick2018: For practical reasons, we decided against using a ventilated façade—mainly due to costs, and also because the overall wall buildup would have become disproportionately thick compared to our small building volume.
However, I thought that a ventilated curtain wall façade generally doesn’t affect the insulation itself, at least not in terms of increasing the thermal resistance of the construction. Its main function is more to support moisture transport and cooling from solar radiation.
@guckuck2: I’m especially considering using XPS boards with HFO-1234ze as the blowing agent to achieve better insulation performance at the same thickness. So far, I haven’t found a similar option from any manufacturer for EPS. Additionally, I hope it’s more resistant to moisture and avoids a drastic material change within the insulation layer. Since the basement floor is partially underground but also has a terrace on top of the “basement roof,” it would be necessary to switch from XPS to EPS and then to PIR within less than 2 meters (6.5 feet), which seems a bit unusual to me.
But I don’t want to hijack rick’s thread—I'll create a separate one for this topic at some point.
@Harakiri Insulation is not just about keeping out the cold, as you already mentioned. Especially with heat, proper ventilation behind the cladding helps a lot. But it also provides some benefit against the cold.
For us, insulation wasn’t the main factor; it was more about the appearance.
If I could have achieved that look more affordably, we would have gone for it.
Daniel-Sp15 May 2020 08:47Hello rick2018,
which outdoor Wi-Fi access point have you planned? Inside the house, I am using the Ubiquiti UniFi NanoHD and am very satisfied with it. However, they are only approved for indoor use. The Access Point Pro models are no longer quite up to date. I am considering using the AC Mesh Pro. What did you decide on?
Regards, Daniel
Regards, Daniel
Daniel-Sp15 May 2020 09:28You can report back soon; I still need to run the cable. One more question: Ubiquiti recommends installing a surge/lightning protector at both ends of the outdoor cable. Did you implement it that way?
