Created on: 11 Sep 2018 07:32
rick2018
Now a bit about me:
Greetings from Swabia
Modern villa with flat roofs, terraces, glass surfaces, green surroundings – several views.
rick20188 Apr 2020 07:12
Why not? What would you have done?
This has already been discussed here as well.
It is sealed multiple times (one layer more than the manufacturer recommends). The other roof sections will be greened. Partly deeply greened with grass (garage roof). The roof itself is made of waterproof concrete. Nothing should get through it during our lifetime.
Even during the shell construction, no water entered through the roof when it rained for more than a week.
guckuck2
8 Apr 2020 07:17
bortel schrieb:
why did you have the roof built with a bituminous membrane?
Check from post 554 onwards. This roof is built to last forever.
andimann8 Apr 2020 07:23
Hi,
apokolok schrieb:
This is definitely the tidiest construction project ever.
I think the same every time I see the pictures. Do you send a cleaning crew through the house before each photo, or do you have a team of surgeons building the house? I have seen hospitals that were less organized...
Anyway, very impressive...!
Andreas
tumaa
8 Apr 2020 07:27
andimann schrieb:
I always think the same when I see the pictures. Do you send a cleaning crew through the house before every photo, or do you have a team of surgeons building the house? I have seen hospitals that were less tidy...
Andreas
I think it’s more likely that they are skilled craftsmen... Rule number one: if you want to be a good craftsman, always leave your workplace clean.
rick20188 Apr 2020 07:49
@andimann There has never been a cleaning crew in the house. @tumaa was right about that. Skilled tradespeople clean up after themselves once the work is done. Of course, we do have some dirt, dust, and waste, but it stays within reasonable limits.
Since the floor structure was just installed, sweeping was necessary. All the debris fit into two 10-liter (2.6 gallon) buckets.
There is also some rubbish outside (like a few screws, wood scraps, plastic sheeting, etc.). Still, I really can’t complain. I do place importance on this. The roofer left a lot of offcuts lying around. When he came back to finish the pavilion, he disposed of everything after being reminded.
Maybe it’s not just the tradespeople, but also related to the construction method. We don’t need to chase cables into walls since empty conduits are installed everywhere...
Climbee8 Apr 2020 08:45
As always, very exciting! The flooring isn’t exactly my style visually, but I believe it feels good (at least that’s how it sounds from the description).
And I can only agree: good craftsmen clean up. Our site was always tidy too, which impressed me every time. I’ve seen very different construction sites.
We currently have a 6 kWp system and are considering expanding. When the sauna is heating up and I’m roasting a joint in the oven pipe, while also cooking on the stove and the extractor fan is running, our self-generated electricity is far from sufficient.
Battery storage was/is still too expensive for the capacity you get. But a connection is planned.
If you, rick, say you had a good offer—may I ask how much battery capacity, which manufacturer, and what it cost?
