Created on: 11 Sep 2018 07:32
rick2018
Now a bit about me:
Greetings from Swabia
Modern villa with flat roofs, terraces, glass surfaces, green surroundings – several views.
rick201810 Jun 2020 21:42
The last period has been a bit stressful.
The ceiling installation is quite advanced. Lights are being installed. Almost all indoor access points are in place.
Painting is also finished except for the stairwell. It is only primed and will be fully painted after we complete the final touch-ups.
There have been some schedule changes. Some appointments cannot be moved. The result is that next week we will have a “full house.”
On Monday, the facade installer will begin fitting the aluminum composite panels, the pool contractor will arrive, we will sand the floor on one level, the utility provider will finally deliver the electricity meter, the electricians will be on site, as will the ceiling installers and the plasterer (pavilion)...
On 06.07., the remaining glass installation is scheduled to start.
Keep your fingers crossed that everything goes roughly according to plan.
Bauherr am L
11 Jun 2020 08:29
@rick2018 you pay attention to details, and I assume even more so with such a beautiful ceiling.
Besides the access point shown, which models have you chosen for smoke detectors and spotlights to ensure they look good and match well together?
rick201811 Jun 2020 10:32
@Bauherr am L That was indeed not so easy. After all, it’s not just about the appearance but primarily about the functionality.
The access points indoors are all Unifi NanoHD. There are design covers available for them as well. Unfortunately, the wood finish is too dark for our light wood. So, they remain in matte white.
The recessed lights are from Bega (with DALI power supplies) and are anthracite. This matches perfectly with our flooring. In the garage and fitness area, they are larger.
The supply and exhaust air vents are white. We didn’t like stainless steel, nor black.
The occupancy sensors are also anthracite. Different models depending on the room. Mostly from Theben.
The smoke detectors come from Jung and have a light wood finish.
The pendant lamp in the dining area will be rose copper.
All ceiling fixtures are round.
Only in the laundry/ironing room (like in the technical rooms) do we have LED strips. Also anthracite.
Brainstorming
11 Jun 2020 22:06
It's really enjoyable to follow this thread. Could you please show your lighting setup? I'm curious how you solved it.
Climbee11 Jun 2020 23:48
More pictures, pleaseplease!
Bauherr am L
12 Jun 2020 20:42
rick2018 schrieb:
@Bauherr am L That was indeed not so easy. After all, it’s not just about the appearance but primarily about the function.
The indoor access points are all Unifi NanoHD models. There are also design covers available for these. Unfortunately, the wood finish is too dark for our light wood, so they will remain matte white.
The recessed lights are from Bega (with DALI power supplies) and are anthracite. They match our flooring perfectly. Larger ones are installed in the garage and fitness area.
The supply and exhaust air vents will be white. We didn’t like stainless steel, nor black.
The motion detectors are also anthracite, in different versions depending on the room, mostly from Theben.
Only in the laundry/ironing room (as well as in the technical rooms) do we have LED strips, also anthracite.
Is the ceiling already far enough along anywhere so that you have photos showing more than just the access point?
