Created on: 11 Sep 2018 07:32
rick2018
Now a bit about me:
Greetings from Swabia
Modern villa with flat roofs, terraces, glass surfaces, green surroundings – several views.
k-man2021
25 Apr 2026 19:47
Load transport individually not at all)
That's true, I didn't consider that at all! The load can't press the dead man's switch ;-) By now, the home lift would definitely be out...
rick201826 Apr 2026 06:12
@k-man2021 thanks for the clarification regarding the home lift. I’m really surprised how much the prices have changed. At these prices, the decision for an elevator would be an easy one.
The question of whether I would do anything differently has come up before. The points are basically still the same.
We installed the photovoltaic system ourselves and replaced the inverter and batteries. The electrician only took care of the registration. There have been quite some developments in this area, both in terms of cost and the general conditions. Further expansion would require a significant effort. Maybe at some point.
This summer, we will install a large heat pump (100kW (340,000 BTU/h)) for the pool. Fortunately, I have a friend who works in this field. We’re doing everything ourselves as well. Since I get the heat pump through Asian equity, it will pay for itself within one pool season.
If I were doing it now, I would size the air conditioning system larger from the start. But that issue has also been resolved. The technical room now has its own separate air conditioning unit.
