Created on: 11 Sep 2018 07:32
rick2018
Now a bit about me:
Greetings from Swabia
Modern villa with flat roofs, terraces, glass surfaces, green surroundings – several views.
rick201816 Jun 2020 22:52
Rolex is very common. There is a reason why they don’t make models with a display case back. It is actually a robust tool watch. I also like some vintage models.
The wearer has to like it and it has to suit them.
With all the hype, there are several watches I would consider buying. But I don’t need any and prefer to invest in my new home.
I still have an old Casio somewhere. It’s iconic. However, I prefer mechanical watches.
Muc1985
16 Jun 2020 23:47
The only thing that comes to mind is the Rolex crisis in Munich in 2019...
11ant17 Jun 2020 00:20
rick2018 schrieb:
I also have a watch from my great-grandfather and some from my father.
Great-grandfather *smile*
Muc1985 schrieb:
This only reminds me of the Rolex crisis in Munich in 2019...
Amusingly, I found a comment in "Die Zeit": The mayor of Munich, Dieter Reiter (SPD), also received death threats after he wrote in a Marie Antoinette manner: "If they can’t get a Rolex, then they should just buy a Breitling."
Alessandro
17 Jun 2020 08:20
I didn’t know that there are some watch enthusiasts here.
Watches are my greatest passion and a hobby that takes up an incredible amount of my time.
Bauherr am L
17 Jun 2020 22:04
rick2018 schrieb:
@rick2018 Could you tell us a bit about your network? I'm particularly interested in how you set up the patch panel, switch, and router.
Have you considered using In-Wall Access Points instead of mounting the NanoHD on the ceiling? UniFi offers some interesting options in that regard. I'm wondering if that could be an alternative since those devices can be cleverly concealed. I’m not really keen on cluttering the ceiling too much. We want the setup to look as tidy as possible. There will be enough going on at the ceiling anyway...
How many access points do you have for your house, or access points per square meter?
rick201817 Jun 2020 22:42
@Bauherr am L there was some discussion about the network a few pages earlier.
It’s no longer a "home setup."
Patch panel -> 1 Gbps switch -> 10 Gbps switch with 20 Gbps connection -> 10 Gbps router.
It is also a 10 Gbps router.
Access points should be mounted on the ceiling. Hiding them reduces performance.
More access points per square meter won’t help if you don’t consider the local conditions.
We have reinforced concrete walls. Don’t expect reliable coverage in the next room. Maybe a very weak 2.4 GHz signal at best.
Since I’m tech-savvy, we have more devices than strictly necessary. I want good 5 GHz coverage in frequently used areas.
In the garage, I have only one access point for about 170 m2 (1,830 sq ft). In the "private room area," there are three access points for a similar area. Outside, there are four access points covering a total of 2,500 m2 (26,910 sq ft)...
In total, I have 15 access points.
There are already several things on the ceiling (smoke detectors, sensors, lights, mechanical ventilation systems...). With a suspended ceiling made of drywall, for example, you can hide devices behind an access panel. This only slightly reduces signal reception.
You can also try using decorative films.
