ᐅ Which router works best with Ubiquiti devices?
Created on: 1 Aug 2020 10:12
Ötzi Ötztaler
I am currently in the process of selecting and purchasing network devices. For Wi-Fi, it will probably be the UAP-AC-PRO (one per floor), unless the Ubiquiti Wi-Fi 6 access point is released in time. Side question: Would it be worth waiting and using an older interim device until Wi-Fi 6 is available? From what I understand, Wi-Fi 6 mainly offers advantages with many simultaneous users, which is rather uncommon in a single-family home.
The PoE switch will likely also be from Ubiquiti, a 16-port model with 150W. Alternatively, it could be Netgear. VLAN might be useful to separate some devices cleanly from the network, but it’s not absolutely necessary.
For the video door intercom system, I am still considering 2N, Doorbird, and Gira (see another thread—I haven’t decided yet).
Now the question: I have read mixed reviews about the USG “router.” Would it be better here to use a FritzBox with Wi-Fi disabled? Or what would you recommend? The FritzBox has the advantage that you can also connect landline phones directly through it. Which other providers besides FritzBox are recommended here? The Wi-Fi performance of the router does not matter; it’s about convenience and many nice features. It doesn’t need to be semi-professional. QoS features for stable IP-TV streaming while the kids do large downloads would also be advantageous.
Thanks in advance!
annab377
3 Aug 2020 11:59
Is there a network diagram or schematic of an ideal network installation for a single-family house?
Including router, switches, access point, firewall, etc.
rick20183 Aug 2020 12:25
Magenta can work with detours. Not suitable for beginners.
You don’t need a diagram. Install everything centrally in one cabinet.
Router, switch, and then the end devices at the point of use. The extent and connection method depend on the local conditions.
In a single-family house, usually one switch is enough. For multiple PoE devices, use a PoE switch right away. Otherwise, use injectors.
K1300S3 Aug 2020 12:35
annab377 schrieb:
Is there actually a network diagram or schematic of an ideal network installation for a single-family home?
An ideal network installation only really exists for a very specific use case—that is, for a very specific house with very specific residents and their particular habits and requirements. For example, I have lived in my house for six years and have completely redecorated it three times due to changing uses and needs, independent of normal technological progress.
Even though this might sound unusual to many and advertising suggests otherwise, it is advisable to have proper expertise for a "typical" home network as well, from an external source if you don’t have it yourself. This includes component selection as well as installation and configuration. You could say that, similar to building the house itself, you need an architect and a construction manager who plan and oversee the implementation. Of course, if you only need “some kind of Internet,” the required experience decreases, but at the same time the risk that something won’t work rises—ranging from Wi-Fi coverage issues to features like guest networks, IPTV services, and so on.
T_im_Norden
3 Aug 2020 13:21
Short version:
At least one double network socket in every room.
For Wi-Fi on each floor, a network socket on the ceiling, for example in the hallway.
All cables end in the utility room, where the network provider’s connection (DSL, fiber optic, cable) is located.
The router is connected there, and the network cables go into the router or into a switch connected to the router, then to the network cables.
This setup covers most common use cases for regular users but allows for adding more components at any time.
hanse987
3 Aug 2020 14:09
Don’t forget secondary rooms like the garage, hobby room, and so on.
If cameras will be installed at some point, prepare for those as well. Also, don’t forget outdoor access points. At least provide conduits for such equipment.
It is important to consider the different devices in advance regarding their positioning and possible space requirements before starting the wiring. When in doubt, consult someone knowledgeable—but please avoid anyone who asks the question themselves in the computer forum.
HarvSpec
3 Aug 2020 14:15
How have you handled IP intercom systems?
I wouldn’t normally connect them directly to my home LAN, so do you use a separate switch or VLAN?
