niri09 schrieb:
Yes, with sand-lime bricks the exterior walls are almost always 17.5cm (7 inches), inside there are some that are also 17.5cm (7 inches) and 11.5cm (4.5 inches). These are sand-lime plan bricks.I am currently working on the electrical installation. There is a DIN standard specifying allowable chase depths and widths without a structural assessment. This becomes challenging with KNX in 17.5cm (7 inches) walls and impossible with 11.5cm (4.5 inches) walls if I understand correctly. Or does the structural engineer usually provide assessments for all wall chases in such constructions?
Steffen8029 Aug 2018 09:54Mechanical ventilation with heat recovery using metal ducts? I would be concerned about condensation issues. Zehnder did not discontinue the metal isobox without reason.
denz. schrieb:
I am currently working on the electrical installation. There is a standard that specifies the allowed chase depths and widths without requiring structural verification. With KNX, this gets complicated at 17.5cm (7 inches) and impossible at 11.5cm (4.5 inches) if I understand correctly. Or does the structural engineer usually prepare verifications for all chases in such buildings?Yes, there are indeed standards for the depth of chases (do other types of blocks not have these?).
We don’t have controlled residential ventilation, yet chases were still made in our building without any issues, even with an 11.5cm (4.5 inch) wall. It’s just harder to cut due to the density of the blocks.
Steffen80 schrieb:
Mechanical ventilation with metal ducts? I would be concerned about condensation. Zehnder did not remove the metal isobox without reason.. For ducts installed within the screed (inside the thermal envelope), I wouldn’t worry about this. The temperature difference between the air and the duct surface is unlikely to be consistently high enough to cause significant condensation.
- Previous
- 1
- 2
- 3
- 10
- 20
- 30
- 40
- 50
- 60
- 70
- 80
- 90
- 100
- 110
- 120
- 130
- 140
- 150
- 160
- 170
- 180
- 190
- 200
- 210
- 220
- 230
- 240
- 250
- 260
- 270
- 280
- 290
- 300
- 310
- 320
- 330
- 340
- 350
- 360
- 370
- 380
- 390
- 400
- 410
- 420
- 430
- 440
- 450
- 460
- 470
- 480
- 490
- 500
- 510
- 520
- 530
- 540
- 550
- 560
- 570
- 571
- 572
- 573
- 574
- 575
- 576
- 577
- 578
- 579
- 580
- 590
- 600
- 610
- 620
- 630
- 640
- 650
- 660
- 670
- 680
- 690
- 700
- 710
- 720
- 730
- 740
- 750
- 760
- 770
- 780
- 790
- 800
- 810
- 820
- 830
- 840
- 850
- 860
- 870
- 880
- 890
- 900
- 910
- 920
- 930
- 940
- 950
- 960
- 970
- 980
- 990
- 1000
- 1010
- 1020
- 1030
- 1040
- 1050
- 1060
- 1070
- 1080
- 1090
- 1100
- 1110
- 1120
- 1130
- 1140
- 1150
- 1160
- 1170
- 1180
- 1190
- 1200
- 1210
- 1220
- 1230
- 1240
- 1250
- 1260
- 1270
- 1280
- 1290
- 1300
- 1310
- 1320
- 1330
- 1340
- 1350
- 1360
- 1370
- 1380
- 1390
- 1400
- 1410
- 1420
- 1430
- 1440
- 1450
- 1460
- 1470
- 1480
- 1490
- 1500
- 1510
- 1520
- 1530
- 1540
- 1550
- 1560
- 1570
- 1580
- 1590
- 1600
- 1610
- 1620
- 1630
- 1640
- 1650
- 1660
- 1670
- 1680
- 1690
- 1700
- 1710
- 1720
- 1730
- 1740
- 1750
- 1760
- 1770
- 1780
- 1790
- 1800
- 1810
- 1820
- 1830
- 1840
- 1850
- 1860
- 1870
- 1880
- 1890
- 1900
- 1910
- 1920
- 1930
- 1940
- 1950
- 1960
- 1970
- 1980
- 1981
- 1982
- 1983
- Next
