Created on: 25 Nov 2015 10:27
Koempy
I'll start right away.
Before March 2014:
After May 2015:
Strahleman
22 Oct 2020 13:35
UpperEast schrieb:
Shared foundation slab for two houses? Hopefully, the sound does not transmit too much.
I wouldn’t even have considered separating the foundation slab for soundproofing. There are so many factors to watch out for or consider.
I personally don’t see it as a major issue. All basement rooms are utility spaces, not living areas, and it’s the same for the neighbors.
11ant22 Oct 2020 13:42
Strahleman schrieb:
I wouldn’t have even thought about separating the slab for sound insulation. There’s so much to consider and pay attention to.
last discussed here: https://www.hausbau-forum.de/threads/maengelbeseitigung-und-schallbruecken.36571/page-2#post-436752
U
UpperEast
22 Oct 2020 13:47
In our housing development, all terraced houses, etc., are built with individual ground slabs. Approximately 6 cm (2.4 inches) gap.
Tolentino22 Oct 2020 13:53
Whether or not you have a basement is completely irrelevant. If you have a concrete slab, sound is transmitted as structure-borne noise from the walls on one side into the slab and then back into the walls on the other side. To prevent this, you need either a separation or a well-absorbing layer between the concrete slab and the walls resting on it.
Tolentino22 Oct 2020 14:10
One more anecdotal addition:
When we had a small cinema installed as a screening room in the basement of a commercial courtyard in Berlin (the rooms above also belonged to us), they basically built a room within a room with decoupling. The costs were six figures.
So, addressing something like that afterwards can be expensive...
Snowy36
22 Oct 2020 14:33
I just can’t understand why there isn’t a standard for this yet... separating semi-detached houses... that would solve the problem... otherwise, you only end up with trouble later on... and the fact that the building savings contract didn’t mention anything about it????
