Created on: 25 Nov 2015 10:27
Koempy
I'll start right away.
Before March 2014:
After May 2015:
Ghostwriter
5 Oct 2017 22:36
Oops, actually, he did... you can see it under the blue foil in one of the pictures.
Surely @Ghostwriter has an explanation for us, or maybe he’s currently pulling up his laminate floor [emoji20]
To be honest, I’m afraid I’ll have to start with your second statement tomorrow. I went by the rule of thumb that a 1cm (0.4 inch) gap to the wall is enough – but Dr. Google says that transition strips between rooms are mandatory in about 90% of cases – I just thought it looked better that way.
I wanted to lay the flooring through the small hallway connecting Kids’ Room 1 and Kids’ Room 2 – the longest planks are about 6m (20 feet) long – the indoor climate should be quite similar in both rooms – do you really think that’s not possible at all?
nelly190
5 Oct 2017 22:39
The laminate flooring instructions specify a 1cm (0.4 inch) expansion gap, and the flooring can be installed in lengths up to 12m (39 feet) and widths up to 9m (30 feet). Check the manual for details. [emoji3]
Ghostwriter
5 Oct 2017 22:45
nelly190 schrieb:
My laminate instructions specify a 1cm (0.4 inch) expansion gap, and it can be installed up to a length of 12m (39 feet) and a width of 9m (30 feet). Check those details. [emoji3]
According to the "package insert," my laminate comes in 10m (33 feet) lengths... Google mentions varying indoor climate conditions—but I’ve also found a few others like me who didn’t have any issues :/
winnetou78
5 Oct 2017 23:01
10 m (33 feet) as stated in the instruction leaflet refers to the laminate itself.
However, any existing expansion joint in the screed must be continued.
Tom1607
6 Oct 2017 06:09
I think this is completely unproblematic. Since the laminate flooring is installed as a floating floor, there is no risk of cracking like with tiles. With a fixed connection to the subfloor, such as tiles or glued hardwood flooring, you need to create expansion gaps, but this is not necessary with floating installation. Movement of the floor is not an issue in this case.
markus27036 Oct 2017 06:10
Risk of breakage is unlikely, but this definitely increases the impact sound transmission between rooms.
