Created on: 25 Nov 2015 10:27
Koempy
I'll start right away.
Before March 2014:
After May 2015:
11ant17 Aug 2020 15:12
Alessandro schrieb:
the glass panel has finally arrived.
And did you celebrate it so enthusiastically that now you’re quite unsteady on your feet?
morph3us
17 Aug 2020 15:16
Alessandro schrieb:
The glass panel has finally arrived.
Looks great! Is it recessed or surface-mounted?
Würfel*
17 Aug 2020 15:31
Stefan001 schrieb:
I absolutely wouldn’t be able to sleep then. But surely a fire insurance won’t cover that anymore, right?
Of course we have fire insurance. A flying spark won’t cause more than a brown spot on the parquet floor. And when I go to bed, I don’t leave the glass door open! I actually think the glass frame is unnecessary. If a spark does fly out, do you really think it would only travel 30 cm (12 inches) sideways? Besides: you should let the wood burn down before adding more (open the fireplace), only when there are just embers left. It takes a few seconds for the logs to catch fire again. By then, my glass door is already closed again.
Brainstorming
18 Aug 2020 07:45
Alessandro schrieb:
flush-mounted
Very cool. What should I consider if I want to install a glass panel flush with the fireplace? I’ve read about this several times and would like to do it the same way.
Alessandro
18 Aug 2020 07:57
In principle, you only need to remove the screed by the thickness of the glass plate around the fireplace.
pffreestyler
24 Aug 2020 10:41
Foundation pit with blue cover, sand mound and wooden posts in front; construction site outdoors.
The concrete slab has been poured. For the first two days, we had to water it thoroughly at 30°C (86°F) to prevent cracking. For the past two days, it has been raining continuously, which has saved us from that. The aerated concrete blocks will be delivered soon. I just need to decide whether to order the density 1.4 or 1.8. Do you think this will have a significant impact on the material's resistance to impacts, for example, from something like a wheelbarrow?
