Created on: 25 Nov 2015 10:27
Koempy
I'll start right away.
Before March 2014:
After May 2015:
ludwig88sta
18 Dec 2019 10:30
I am currently envisioning a kitchen island that does not include a stove or sink. I believe it is easier and more cost-effective to have these installations (ventilation, electricity, water) located in the kitchen wall unit.
Is it still considered a kitchen island if it serves only as a workspace and countertop?
matte
18 Dec 2019 10:36
I installed the toe-kick lighting myself using Philips Hue. For that, I had the kitchen fitter install a power strip in the base cabinet area.
Luckily, we also have a robot vacuum, which already helps keep the overall cleanliness at a good level.
I’m glad I added the lighting, and considering the dust, I see no reason not to do it.
In our case, you can relatively easily remove the baseboards to access the wiring.
In the end, it wasn’t much effort, it was cheaper than having the kitchen fitter do it, and it can also be integrated into KNX.
If you can somehow get power down there, I’d recommend it to you.
Maria16
18 Dec 2019 10:40
ludwig88sta schrieb:
I think both are easier and cheaper if these two installations (exhaust air, electricity, water) are integrated into the kitchen countertop wall unit.
If you are building new, it should basically not matter where you have a pipe or cable installed. While follow-up costs are indeed higher for a stove due to extractor hoods or downdraft systems, I don’t see such price increases for the sink. Regardless, I would ALWAYS try to have one or more power outlets on the island so you can plug in kitchen appliances there as well.
Climbee18 Dec 2019 10:43
We have power supply under the island, so it should not be a problem to set it up at the island. The kickboards are also just clipped onto the legs of the cabinets in our case.
I’m not sure if additional lighting is even needed on the other kitchen run. But that should be doable as well. I’ll ask my dear husband and show him your picture.
ludwig88sta
18 Dec 2019 10:43
Maria16 schrieb:
When building new, it should generally not matter where you have a cable installed. While the additional costs are indeed higher for a stove due to extractor hoods or downdraft systems, I don’t see such price surges for the sink. Regardless, I would ALWAYS try to have one (or more) power outlets on the island so you can plug in kitchen appliances there as well.
I plan to install a vented extractor hood, so the island solution is almost unnecessary. But yes, having the sink on the island could definitely be considered!?
In general, you shouldn’t be stingy with power outlets in a new build. We’re planning to install at least one above every windowsill (especially now during the holiday season, your decorations will thank you).
pffreestyler
18 Dec 2019 12:30
Exhaust air can also be easily managed with an island setup. Two of my neighbors have done this without any problems. You just don’t have a core drill – it goes through the roof. It is probably even the more energy-efficient solution.
