Created on: 25 Nov 2015 10:27
Koempy
I'll start right away.
Before March 2014:
After May 2015:
bortel
2 May 2020 14:18
The film was applied from the inside.
It provides privacy, and I was able to finish the house number right away.
11ant2 May 2020 14:25
Nummer12 schrieb:
A house number displayed as a wall graphic behind a window is quite a brilliant idea.
Nummer12 schrieb:
I initially planned an interior blind to provide privacy while still allowing light in.
For this kind of application, I would probably choose a translucent printed film similar to those used for advertising on city buses. The design could then feature the resident family.
F
fskscorp
2 May 2020 14:28
It is...
View through scaffolding opening onto green fields, trees, wind turbine, and sunny sky.
On construction site: scaffolding, white concrete blocks, yellow YTONG packaging, construction vehicles, and gravel.
Nummer122 May 2020 14:42
It provides privacy, and I was able to prepare the house number at the same time.
Would you reveal the manufacturer? The market seems quite confusing after a Google search. I’m not allowed to send private messages yet....
For such a use, I would probably choose a translucent printed film like the ones used for advertising on city buses. Then the design could be the family living there.
Better not....
11ant2 May 2020 14:51
Nummer12 schrieb:
Better not....
You could make the dog bigger in the picture. Or you could use the Beimers, the Geissens, the Flodders, the Simpsons, the Waltons, the Barbapapa family ...
Climbee2 May 2020 16:26
No rain for weeks, but as soon as we start working on the garden, it pours... and now we have mud everywhere in front of the house. Our karma must not be that good.
Anyway, the first wall is almost finished. Until last Wednesday, the area around our house still looked like this:
Wooden house with horizontal wooden panels, blooming tree in front, garden with grill cover.
Modern wooden house with large windows, shutters, garden and terrace.
Exterior view of a wooden house with outbuilding, open entrance and garden tools.
In good weather, everything was dry and relatively clean (except for pollen).
Now things have changed a bit:
Small construction site with mini excavator next to house, concrete wall on the left, soil and rubble ground.
Backyard construction site: yellow plate compactor on unpaved ground next to wooden shed.
Construction site next to wooden house; unpaved gravel path, excavator on the left, construction equipment in the distance.
Small construction site: gravel path between wooden houses, mini excavator at the end of the property.
Everything wet and muddy... At least the wall to the neighbor is almost finished. There will be a small compost area and my bread oven (towards the shed) and our terrace in front of it. The bread oven will also hide the unsightly exhaust pipe of the controlled residential ventilation system from view. We will come up with something to deal with it, either letting plants climb up it or enclosing it, we’ll see. Once the ground was leveled there, we finally got a better idea of how much space we have. I think it will be enough for us
The finished height will be at the point marked by the arrow here:
Gray concrete barrier with square metal fixture, gravel and soil in front, green background.
The wall will be at this height all around the house, continuing up to the balcony.
Our cats, meanwhile, are annoyed – changes are baaaad and the old wall to the neighbor was wider, which was perfect for lying in the sun (even though it was about to fall over, but that doesn’t matter in the cat world). Everything is different, dirty, and just not right. We currently have three little grumpy ones at home. The fact that they refuse to clean their paws before coming in grumpily is not their problem, but mine. Otherwise, they are hiding in the scratching post, trying to avoid as much of this crazy world as possible:
Cat tower with caves, ropes and hanging basket in the living room next to plants and bookshelf.
