Created on: 25 Nov 2015 10:27
Koempy
I'll start right away.
Before March 2014:
After May 2015:
V
vx220
27 Jun 2019 06:22
@Climbee would you tell me who makes that great window? The bay window looks really nice overall.
Snowy36
27 Jun 2019 06:25
Does anyone actually sit there? Even with cushions, the posture would be too uncomfortable for me to read anything for a longer period.
Z
Zaba12
27 Jun 2019 06:47
Snowy36 schrieb:
Does anyone actually sit there? Even with cushions, the posture would be too uncomfortable for me to read for a longer time.
I always wonder that too, but you could say the same about a fireplace.
Climbee27 Jun 2019 07:22
I do think someone will sit there (at least I will). We only have a mountain view from the upper floor, after all.
With cushions, I don’t think it will be uncomfortable. I really wanted this window because I’ve always enjoyed sitting by windows, and even now I sometimes sit on the (too narrow and cold, since they’re made of stone) window sills whenever possible. Otherwise, I think it’s a good use of space with the shelf, and you can still sit between the sections.
A carpentry company from Langerringen, Bernd Steinhausz, made it. Just look him up online, he even has a website.
Yesterday, the first lights were installed – though not our large fixtures.
We also decided to install the eye-catching living room light (Mercury from Artemide) and the Mitos from Occhio over the (yet to be built) kitchen island later, since they would probably be more of a hindrance right now. I’m already worried the Mercury might be too big for the living room after seeing the box it comes in – oops… we’ll see. We’ll need another appointment later anyway because the lights in the guest bathroom are best installed together with the mirror they will be mounted on. Right now, I’m coordinating the glazier, the kitchen installer, and the lighting specialist to have a coordinated work session in mid-July, where the glazier delivers and fits the mirrors, the lighting expert installs the remaining lights, and at least the kitchen island is in place (the countertop for the island won’t arrive until the end of July, but if the island is already set up, the lights can be aligned accordingly). Sigh…
So, yesterday’s install was rather modest in terms of visible lighting. The (high-voltage) spots in the living room, dining area, and hallway were installed, as well as the ones above the (yet to be installed) kitchen countertop:
Interior under construction: wooden ceiling, long window front, building components/tool stacks, Makita case.
Pay attention to the detail the lighting specialist specifically pointed out to me—the dots on the front:
Wooden ceiling with two round white ceiling lights over a light wall.
Those are the brand’s logo on the lamp! Important! … I really had to think about whether I would have preferred it without the dot in front *ahem*, which shows that I’m obviously not on top of brand design… So now we have the dots at the front to clearly show that these are branded spotlights. If I ever have a visitor who knows their lamps, I can literally “score points” with this! (In the truest sense of the word *lol*)
What’s nice (and the real reason we wanted these spots—not the dots) is the light cone the spots already cast, even without a countertop underneath:
Bright interior with wooden beam ceiling, three ceiling spots, and long horizontal window with garden view.
Our carpenter (the one who made the window seat) has also been busy finishing our stairs.
First, the one to the upper floor, now oiled and therefore darker:
Bright new build apartment with zigzag-shaped wooden staircase along a white wall, building tools in the room.
Modern wooden staircase indoors, construction work; tools, shoes, and materials on the floor; person at the top.
Then also on the side (and once again with protective film on the stairs):
Modern indoor staircase made of brown wooden steps along a white wall.
And the stairs to the basement, too:
Craftsman installing wooden steps on a staircase under construction, building tools nearby.
And immediately protected again with film (I was too slow to catch them without the film once finished):
White modern staircase along the wall with wooden edges, protective film on the steps, door on the right.
The baseboards are now installed in the hallway downstairs – that area is finished!
Bright hallway with light wooden floor, two white doors, protective covering on the floor.
And the sliding door between the bedroom and dressing room is also installed:
Renovation room: open sliding door, ladder, building materials, dark attic area in the background.
It’s coming together!
Dr Hix27 Jun 2019 08:21
@cschiko: Thanks for the well-intended tip. The "problem" is panels of this length that are more than 90cm (35 inches) deep.
@Climbee: You really have a beautiful house, I just keep thinking it was built by a team of executioners.
cschiko
27 Jun 2019 08:43
But shouldn’t a carpenter be able to solve this? Taking two panels and joining them together should be possible. If you glue them properly or additionally connect them from underneath, it should be feasible to create a single panel—at least from the perspective of an amateur who has some experience working with wood. In addition to glue, you could use dowels as connectors or metal plate connectors from below. That way, the panels could be joined so that the connection is not visible, resulting in one seamless panel.
