ᐅ How do I build an Ikea Metod kitchen island with additional storage?
Created on: 16 Aug 2017 09:12
sarfinnHello everyone, I am planning to build an Ikea Metod kitchen island that will provide extra storage in addition to the usual countertop workspace. I want to make the most of all available module widths to combine drawers and pull-outs in the best possible way. It is important to me that the construction is stable and can also accommodate additional kitchen utensils that would normally be stored in cabinets. Has anyone had experience assembling such islands and can share tips on which modules work particularly well, which adhesives or joint methods are recommended, and how to best stabilize the kitchen island? If you also have suggestions on how to use the storage space ergonomically, I would be very happy to hear your advice!
Use mainly drawer modules with full-extension slides, as they are sturdy and provide plenty of storage space. For connecting the modules, it is recommended to use the supplied Metod fittings plus corner connectors. To stabilize the island, you should connect it with a countertop made of thick wood or stone.
The Metod series basically offers standardized module widths of 40, 60, and 80 cm (16, 24, and 32 inches). For a kitchen island, a combination of drawers with soft-close function and tall cabinet units is practical to meet different storage needs. Stable connections can be achieved using the original cross connector screws. It is important to assemble the modules before installation, as the countertop must be precisely aligned before final fixation. Using shelves or special pull-out organizers increases storage space efficiently. Additionally, I recommend securing the island to the floor or at least supporting it in a way that prevents wobbling when loaded with appliances, for example.
I feel the same way as you, sarfinn. When assembling my Metod island, it was important to me to have enough storage space for pots and supplies. At first, I was unsure if the construction was stable enough, but after connecting the modules with the countertop and securing it to the wall with brackets, everything feels very solid. If you have the option, I would recommend attaching the island to the wall at least at one point or using a sturdy base. This makes it feel safer, especially if there are children in the house.
An addition: When using storage space, it is very helpful to combine drawers with slides of different heights. Shallow drawers are suitable for cutlery, while deeper ones are ideal for pots or larger appliances. Modular compartment trays for interior organization should definitely be used to keep everything well structured. Panels or kickboards also contribute to a clean appearance and conceal access points.
FREDRICK schrieb:
The Metod series basically offers standardized module widths of 40, 60, and 80 cm. Thanks for the detailed overview, Fredrick. I had considered integrating 20 cm modules as well, but if that’s not advisable, I will stick to the mentioned sizes.
HORST41 schrieb:
If you have the option, I would recommend attaching the island to the wall at least at one point That’s a good tip; however, I don’t have a direct wall connection next to the island. How have you ensured stability when there is no wall nearby? I am especially concerned about wobbling with layouts similar to free-standing islands.
