ᐅ KALLAX as a Kitchen Island – Potential Issues During Renovation?
Created on: 8 Apr 2021 09:17
Delia
Delia
8 Apr 2021 09:17
Hello everyone, I am currently planning to remodel my kitchen and am considering using an IKEA KALLAX shelving unit as a kitchen island. I am particularly wondering what challenges and issues could arise when converting a KALLAX shelving unit into a fully functional kitchen island. I am aware that the KALLAX is not originally designed as kitchen furniture, so I am especially interested in how to best address stability, water resistance, and the integration of electrical appliances or connections. Does anyone have experience with this or can point out technical problems that are often underestimated? Thanks in advance for your insights!
nonere
8 Apr 2021 10:03
Hello Delia, basically the KALLAX system is not designed for use in the kitchen area, especially not as an island that will endure heavy use. The materials are mainly particleboard with lacquer or paper surfaces, which can be problematic when exposed to moisture. You would need to apply water barriers and suitable sealing if you want to place it near the sink or cooktop. Stability is also a concern: the weight of countertops, appliances, or cutting areas can overload the shelves, especially if these are large surfaces without additional bracing. For electrical installations, there are no predefined conduits or cable channels—careful planning and adaptation are necessary here, ideally with professional advice. In general, I recommend using KALLAX rather as additional storage rather than the main island, or reinforcing the shelves solidly with load-bearing elements.
Danial
8 Apr 2021 11:27
Interesting approach, Delia. However, I wonder if it might be more practical to invest in a sturdy kitchen island or at least use a different base than the KALLAX.
If that is already a significant drawback, how safe can you be that nothing will swell or, in the worst case, develop mold? Are there any experiences or examples of how these issues can be permanently resolved with a sealant? I would also be interested in how to properly distribute the weight – the KALLAX system is modular but has limited load capacity. Are reinforcements easily possible, or do compatibility issues arise?
Z
zartra
8 Apr 2021 11:45
Regarding stability: KALLAX units support approximately 13 kg (29 lbs) per shelf. For a worktop, additional supports or reinforced panels should be used. Moisture protection is essential, for example, with special coatings or membranes. Electrical work should always be carried out by a professional.
Surela
8 Apr 2021 14:12
Delia, you’ve already raised some important points. I would like to analyze the issue systematically. First, stability: the KALLAX system is designed for light to moderate loads, such as books or decorative items, not for kitchen work or heavy appliances. To support a countertop and moderate loads, I recommend reinforcing the shelves from underneath with a sturdy support structure. This will reduce point loads but improve the overall stability. Second, the material: standard KALLAX is neither water-resistant nor resistant to heat or grease splashes. Sealing with epoxy resin, polyurethane coatings, or applying a water-resistant film can help, but this is labor-intensive and must be carried out carefully. Third, the electrical installation: for kitchen appliances, it’s best to run wiring in cable conduits, which you can either mount externally or route behind the structure. Integrating the electrical system without professional planning quickly leads to hazards. Last but not least, consider your floor attachment: not every KALLAX module has optimal contact with the floor—when used as a kitchen island, there is a risk of tipping if the load is not evenly distributed. My question for you: how exactly do you envision using it? Do you plan to have a sink, stove, or only a work surface? Are you planning built-in outlets or other connections? This would have a significant impact on the technical feasibility.
BeAndrea
8 Apr 2021 16:38
Hello Delia, I wanted to add that when it comes to water resistance, you should also consider maintenance and cleaning. Especially when working with raw food or accidentally spilling something, a KALLAX unit that isn’t properly protected can be damaged quite quickly. Another tip is to use flexible coasters or small feet under the shelf to compensate for uneven floors and to improve air circulation. Although it may look like a nice DIY project at first glance, please remember that hygiene in the kitchen is especially important. For solid work surfaces, I would definitely recommend adding an additional, more suitable panel on top, such as a sturdy plywood board, which is then oiled or lacquered for protection.
