Hello everyone, I’m currently considering how to use the IKEA BESTA system as a small kitchen island. My kitchen is relatively small, so I’m looking for a flexible and cost-effective solution.
Specifically, I’m interested in the following points: How can I modify the BESTA to make it stable and sturdy enough for a kitchen island? What adjustments make sense to optimally combine storage space and countertop surface? Do you have any tips regarding the choice of countertop or practical extras like casters, power outlets, or lighting?
I’m looking forward to your ideas and experiences, as I’ve only known BESTA as a TV unit so far, but I’d like to know if it’s also suitable for use in the kitchen.
Daledra schrieb:
The best setup is to equip the BESTA with sturdy legs and place a worktop on it that is heat-resistant and durable. Thanks for the tip, having sturdy legs is very important to me since the island needs to be movable but must not wobble.
memiriam schrieb:
I would recommend checking the depth of the BESTA – the standard dimensions are usually not quite optimal for a kitchen island. Exactly, I found the dimensions a bit tight, which is why I thought about connecting several units. A more elongated island would work better.
Does anyone have practical experience with fixing the worktop? Do you just attach it on top, or are there special brackets that make sense for movable furniture?
I find the idea of using Ikea BESTA as a kitchen island basically interesting, but I consider it to be of limited practicality.
The system is not designed to withstand kitchen loads, moisture, and heat, which you should not underestimate.
Regarding stability: Have you already checked whether the standard legs can support the weight of the countertop and occasional leaning? Common heights for BESTA are around 38 cm (15 inches), so you may need to adjust this to ensure the island is ergonomically suitable.
For the countertop: Simple installation with screws from above is possible; to achieve more stability, I recommend adding brackets or metal profiles under the countertop and screwing them to the BESTA carcasses. Simple clamping or standing solutions can quickly become wobbly or break with movement.
On the topic of storage space: The internal depth of about 40 cm (16 inches) may be too shallow for kitchen utensils if you want to store larger pans or pots, for example. Simply placing modules side by side does not automatically solve the problem; the units should rather be connected and reinforced.
I also wonder how well the design will match the rest of the kitchen cabinets later on – often the BESTA style is already quite domestic and does not necessarily suit a functional kitchen look.
blaix schrieb:
The system is not designed to handle kitchen loads, moisture, and heat; you shouldn’t underestimate that. I completely agree. The typical melamine board used in BESTA is not very resistant to moisture.
It’s also questionable whether using casters will provide enough stability – a kitchen island has to withstand quite a bit (work pressure, cutting, heat).
In my opinion, screwing the countertop and base cabinet together is a weak point. If it’s stressed incorrectly even once, stability is gone.
However, small kitchens often involve makeshift solutions. A compromise within reasonable limits is certainly possible, but you should be aware beforehand that you might be creating something mainly for visual effect and storage, rather than a professional-quality kitchen island.
