ᐅ How can Ikea BESTA be adapted for outdoor use?
Created on: 23 Feb 2024 10:12
Pogono
Pogono
23 Feb 2024 10:12
Hello everyone, I am currently considering how to modify the Ikea Besta system to make it suitable for outdoor use. My main question is: what measures and modifications are necessary to make the furniture weather-resistant without losing the flexibility and modular design of the system? Specifically, I am interested in which materials should be replaced or supplemented, whether there are effective surface sealants, and how to adapt the construction to withstand moisture, UV radiation, and temperature fluctuations. Additionally, I would like to know if there are any recommendations for fastening and combining it with outdoor-specific components to ensure stability without limiting transportability. Thanks in advance for your expertise!
Ankeli
23 Feb 2024 10:45
To make BESTA suitable for outdoor use, you should first treat all wooden parts with a high-quality outdoor wood varnish. I also recommend sealing the edges and joints with a waterproof sealant. For the feet, it is better to use rust-resistant metal brackets or appropriate plastic gliders. Plastic parts can be left as they are, as long as they are UV-resistant.
Nathanaelk
23 Feb 2024 11:17
The main challenge when converting Ikea BESTA for outdoor use lies primarily in the material composition: the MDF and particleboard used are not designed to withstand moisture and wet conditions. Therefore, I would recommend thoroughly sanding all wooden parts first and then treating them with a combination of wood primer and several coats of weather-resistant wood stain. Pay special attention to the edges, as moisture tends to penetrate most quickly there. Alternatively, replacing these parts with weatherproof plywood or marine-grade plywood is an option if the budget allows. For the back panel, you should also use a sturdy, moisture-resistant material, such as plastic or aluminum composite panels. Screws should be replaced with stainless steel or galvanized ones to prevent corrosion. It is also advisable to mount the unit on a platform or use spacers to prevent standing water at the base. Do you already have an idea of what functions your outdoor BESTA should serve (e.g., storage, seating, shelving)? That would help to further specify the recommended modifications.
Pogono
23 Feb 2024 13:04
Nathanaelk schrieb:
Do you already have an idea of which functions your outdoor BESTA should have (for example storage, seating, surface)?
Thanks for the suggestion! Mainly, I want to create weather-protected storage, possibly with a surface on top that can also serve as a small seat. Stability is important to me because it will be placed on a covered terrace, where it can get damp and windy at times. It doesn’t need to be completely waterproof, but the material should not soak through or warp.
andre3
23 Feb 2024 13:45
In summary, please note the following:
- Material: BESTA furniture is primarily made of MDF and is not designed for exposure to moisture.
- Surface treatment: Apply at least 2-3 coats of weather-resistant varnish (e.g., polyurethane-based).
- Edges should be carefully sealed (special edge sealing products are recommended).
- Screws: Replace with stainless steel or galvanized fasteners.
- Installation: Avoid direct contact with the floor to prevent moisture exposure (e.g., use rubber feet or a platform).
- Optional: Replace back panels with PVC or aluminum sheets.
For seating surfaces, it is advisable to use a durable weatherproof cushion or special outdoor wood panels (e.g., teak or bangkirai) as a cover.
Ankeli
23 Feb 2024 14:10
One more tip: You can add rubber seals to the doors to reduce water ingress. Installing small weather protection canopies or eaves above the furniture could also help extend its lifespan.
