ᐅ Are there effective methods to increase the load capacity of Ikea Besta furniture?
Created on: 11 Feb 2020 08:47
Dopo32
I am currently researching whether there are effective methods to significantly increase the load-bearing capacity of Ikea Besta furniture. Specifically, I want to know how to load these shelves or cabinets more heavily without compromising their stability or safety.
I understand that Ikea products are generally designed for household use, often featuring relatively thin panels and fittings. I am interested to hear if anyone has practical experience or proven techniques to achieve higher load capacity, for example through reinforcements, additional fastenings, or other structural modifications.
Perhaps there are also support frames or special constructions that can be added to make the furniture sturdier. It is important to me that the solutions are feasible for DIY work and do not drastically alter the original design of the Besta modules.
I look forward to your tips, experiences, and recommendations!
lomin
12 Feb 2020 08:56
I really like the discussion here! Especially when a shelf is heavily loaded, it’s natural to worry about whether everything will remain secure.
Reinforcing the back panel sounds great, but I would recommend attaching the extra screws and brackets carefully and not placing them too close together. Otherwise, the material could become brittle or start to tear over time.
From my own experience, it’s better to build slowly and check periodically how the stability develops.
Once the piece of furniture is fixed to the wall, it provides a lot of security and makes things much more relaxed; this way, the risk of something tipping over or, in the worst case, falling is minimized.
feklo
12 Feb 2020 11:23
Regarding the question "Are there effective methods to increase the load capacity of Ikea Besta furniture?" I would like to provide a brief guide:
- First, remove the back panel. It is usually made of particleboard or hardboard, which contributes little to the overall stability.
- Secure a new plywood panel (or multiplex board) with a thickness of 12-18 mm (0.5-0.7 inches) using screws. This significantly improves the cabinet’s rigidity.
- Replace the shelves with plywood or wooden boards, optionally supported by metal brackets underneath.
- Check the side and bottom panels for reinforcement possibilities. Additional brackets and screws here can significantly strengthen the furniture.
- Don’t forget to anchor the unit to the wall! Even with internal reinforcements, wall mounting is absolutely necessary.
Common mistakes:
- Using too many thin screws placed too close together
- Overloading individual shelves
- Skipping wall mounting
Conclusion: Yes, there are practical, craftsmanship-based methods to make Besta furniture more robust. However, it requires some effort and material investment.
posin50
12 Feb 2020 13:47
Great tips here!
I had the problem that my Besta shelf in the living room was wobbly whenever the child climbed on it – which, unfortunately, happened quite often. 🙈
I then installed a plywood panel as a backboard and additionally reinforced the shelves. Since then, the shelf has been rock-solid, even under heavy load.
It definitely works, everyone! Don’t get discouraged 😊💪
Dopo32
13 Feb 2020 09:32
leomo schrieb:
The interior structure can be reinforced with relatively simple methods, such as adding extra brackets or metal profiles to the edges.
Thanks for the feedback so far!
I’m still interested in whether you have more specific recommendations regarding types of screws and brackets? At the hardware store, I’ve seen steel brackets, but also lighter ones made of aluminum or even plastic.
From your experience, which material is best suited when both load-bearing capacity and subtle appearance are important?
Also, I’d like to know if there are any considerations regarding wood moisture when retrofitting with plywood panels to prevent warping.
I appreciate any detailed advice!
Giagau
13 Feb 2020 11:05
For angle brackets, galvanized steel or powder-coated steel brackets are indeed the best options in terms of load-bearing capacity. Aluminum is lighter but doesn’t have the same strength, and plastic brackets are more decorative than structural.
Regarding wood moisture content, plywood panels used in furniture making are usually well dried (<10% moisture). It is important to acclimate the panels at room temperature for a few days before installation to avoid stresses.
During installation, watch out for any residual moisture and avoid overly humid environments to prevent warping.
