Hello everyone, I am considering using Ikea Besta furniture in a damp room, specifically in a part of our basement that occasionally gets a bit damp and has elevated humidity levels. My question is: How can I effectively protect the BESTA furniture from moisture to prevent warping, surface damage, or mold growth? Are there proven methods, special materials for surface treatment, or alternative installation options that might help? I look forward to your expert tips and experiences.
I also have my Besta furniture in the basement and can say: with some effort, it is really durable! It is important not only to seal the outside thoroughly but also to pay attention to the back and inner sides of the panels. I coated everything with a special marine varnish – excellent durability! It was a bit of work, but definitely worth it.
And don’t worry, if your furniture is on legs and air can circulate underneath, the protection is much more effective. Just regularly clean with a damp cloth, dry the surfaces afterward, and check the seal once a year. That way, you can enjoy it for a long time!
bauku schrieb:
I also have my BESTA furniture installed in the basement and can say: with some effort, they are really sturdy! It is important not only to seal everything well on the outside but also to pay attention to the back and inner sides of the boards.That may be true, but we should not forget that Ikea furniture is primarily designed for living spaces. The idea of using it in damp conditions goes against the manufacturer's specifications. Sealing does not change the fact that the particleboard inside will swell, and the stability will decrease over time.
It might work in the short term, but I would generally advise against it unless the room is permanently climate-controlled and kept dry.
theota schrieb:
The idea of using them in damp conditions contradicts their manufacturer specifications.Exactly! The question always involves economic and practical considerations. I recommend weighing the risks and, if in doubt, opting for appropriate materials specifically designed for wet areas.
On the other hand, depending on the location of use, certain sealants and drying strategies can provide a compromise if the budget is tight or the furniture piece is only intended for temporary use.
I actually got some simple plastic sheets for my basement, attached them to the back of the BESTA furniture, and additionally treated the underside with waterproof varnish. This significantly improved the moisture resistance!
It is important not only to work on the surface but to seal all potential entry points for moisture. I am very happy with my method and can only recommend doing this systematically.
Hey, I just wanted to mention that while moisture is always an enemy of wood-based materials, with some patience and attention to detail, you can achieve quite a lot even with Ikea BESTA furniture!
The most important thing is not to get discouraged and to regularly check how well the sealing holds up. The furniture is really versatile in use, and the look is great! 😊
My tip: Start with small test pieces to try out the sealing, and then gradually make the furniture more secure.
Ezekiel schrieb:
Place furniture slightly elevated, for example on legs or boards, to prevent standing moisture from the floorladali schrieb:
Additionally cover the back panels on the inside with a moisture-resistant foilMany thanks to everyone who shared such detailed tips! For now, I plan to install the furniture slightly elevated and treat it with a waterproof polyurethane (PU) finish. I will also seal the backs and edges additionally.
If I later find that the moisture levels are too high, I will add the suggested foils and coatings. Thanks also for the critical assessments; they help me make a realistic evaluation. I will report back here with my experiences!
