ᐅ Which materials are suitable for creating a custom front for IKEA Besta units?
Created on: 27 May 2018 09:12
kerolisHello everyone,
I am planning to build a custom front panel for my IKEA Besta shelving unit and am looking for the best materials suitable for this purpose. It is important to me that the front panel is sturdy, relatively easy to work with, and visually appealing. Additionally, the material should absorb minimal moisture and ideally be easy to paint or coat. Does anyone have experience with suitable materials for front panels? What are the pros and cons of options like MDF, plywood, or HPL panels?
I look forward to your advice!
Hello kerolis,
Good front materials for IKEA Besta units are typically MDF in various thicknesses, veneered plywood, or HPL panels. MDF is affordable, easy to sand and paint, and fairly dimensionally stable, but it must be well sealed as it absorbs moisture. Plywood is more durable, has an attractive natural wood grain, and is somewhat more expensive, but offers better long-term resistance. HPL panels provide a very durable surface that is waterproof and scratch-resistant, but they are harder to cut and usually more costly.
FABIAN_DEO27 May 2018 11:27Hello kerolis,
I can provide you with a detailed overview:
- MDF: Medium-density fiberboard, very uniform and smooth, perfect for painting. It is important to use a moisture-resistant type or apply a good sealant, as regular MDF tends to swell significantly when exposed to moisture. It is also easy to work with using CNC machines or manual tools.
- Plywood / Multiplex: Made of several glued layers, which makes it very stable. Because it is wood, you can use either stain or clear varnish, giving a very natural look. However, it is more expensive and heavier than MDF.
- HPL (High-Pressure Laminate): Made of multiple plastic layers fused together under heat and pressure. It is highly resistant to scratches and moisture, but cutting it requires special tools because the material is very hard.
- Important: Check the thickness of the material; 12 to 18 mm (0.5 to 0.7 inches) is a good choice for fronts, so they don’t appear too thin and remain sturdy.
For your information: If you want to paint, MDF with an appropriate primer is the most common choice in the DIY sector. For veneer or real wood finishes, multiplex is ideal.
FABIAN_DEO schrieb:
MDF: Medium-density fiberboard, very homogeneous and smooth, perfect for painting.I can confirm that. MDF has a very consistent surface, which really makes a big difference in the finish. Especially with matte paints, you can immediately see if the base isn’t smooth enough. I would also add that when working with MDF, you should definitely wear a dust mask, as the dust is harmful to health.
