ᐅ Are there modular storage solutions with IKEA BESTA that can adapt to changing needs?
Created on: 25 Sep 2024 08:23
BashkimHello everyone, I would like to start a discussion about modular storage solutions, specifically in relation to the IKEA Besta system. I’m interested in whether there are practical ways to use Besta flexibly and modularly so that storage can be adjusted in everyday life to changing needs—whether through reorganization, purchasing additional modules, or alternative uses of the components. Does anyone have experience with how suitable Besta is for dynamically changing furniture and storage, for example with frequently changing living arrangements, usage scenarios, or seasonal needs? Which components should definitely be taken into account? Thanks in advance for your insights!
PeoDaniel25 Sep 2024 09:45Hello Bashkim, your concern is completely understandable. The IKEA BESTA system is indeed designed to be very modular – the individual cabinet units can be combined flexibly and expanded later on. It is important to pay attention to the different depths (e.g., 20cm (8 inches) or 40cm (16 inches)) as well as the various widths in order to create well-coordinated modules later. Especially with changing requirements, the optional internal fittings, such as baskets, drawer inserts, or shelves, are very helpful. A tip: plan a little extra space at the beginning, so you can more easily add or modify elements without having to replace everything.
The best practical experience I have had is with the use of modular shelving units at different heights. You can combine individual BESTA elements to flexibly adjust the storage space. I also consider the ability to easily swap doors and drawers a major advantage when requirements change.
Another important aspect is the castors and feet that can be attached to BESTA units. Especially in situations where the setup changes frequently, mobility is a significant advantage. This allows cabinets to be easily moved or temporarily repositioned for seasonal use, for example.
Thank you for the initial helpful suggestions! The idea of a flexible back panel without fixed mounting sounds particularly interesting. Do you have specific recommendations regarding the choice of material and stability? Or perhaps special internal organizers that are easy to reuse? The goal is to make modifications as simple as possible.
