Hello everyone, I’m currently considering how to use the IKEA BESTA system as a small kitchen island. My kitchen is relatively small, so I’m looking for a flexible and cost-effective solution.
Specifically, I’m interested in the following points: How can I modify the BESTA to make it stable and sturdy enough for a kitchen island? What adjustments make sense to optimally combine storage space and countertop surface? Do you have any tips regarding the choice of countertop or practical extras like casters, power outlets, or lighting?
I’m looking forward to your ideas and experiences, as I’ve only known BESTA as a TV unit so far, but I’d like to know if it’s also suitable for use in the kitchen.
Here are some facts about using Ikea Besta as a kitchen island:
- Load capacity: The cabinets are designed for light to medium weight, not for heavy countertop loads.
- Material: The melamine-coated particle boards are sensitive to moisture penetration and heat.
- Assembly: The countertop should be securely attached to the cabinets with at least 4–6 screws. Additional metal brackets increase stability.
- Dimensions: Individual modules are approximately 40 cm (16 inches) deep; placing two modules side by side offers about 80 cm (32 inches) depth, which is more ergonomic.
- Casters: Only use casters that are rated for heavy loads and equipped with locking brakes.
Alternatively, a sturdy tabletop (e.g., plywood or solid wood) can be cut to size to improve both appearance and function.
In summary: yes, it is possible, but use comes with certain limitations.
For a small kitchen island, I would recommend using the BESTA units as storage base and mounting a separate, stable countertop on top.
mintra schrieb:
For a small kitchen island, I would recommend using the BESTA as a base for storage and mounting a separate, sturdy countertop on top.That matches my idea quite well. Do you have any recommendations on the material or thickness of the countertop when placed on the BESTA, considering it should be both sturdy and easy to maintain?
Muso4 schrieb:
It’s also questionable whether you can really achieve stability with casters – a kitchen island needs to withstand quite a bit (work pressure, cutting, heat).I was only thinking of casters with locking brakes for flexibility, mainly to move the island around the room when needed – but of course, it should be stable overall.
If casters cause problems, would small floor protectors or another type of mobility solution be a possible alternative?
For the countertop, I recommend at least a 26mm (1 inch) plywood board, as it is sturdy and handles loads well.
Painted or oiled surfaces are easier to maintain.
Wheels are only advisable if they are solid and durable. Otherwise, it’s better to avoid them or use furniture feet with rubber pads to protect the floor.
I think it’s great to use the Ikea BESTA system as a small kitchen island, especially when the kitchen is small and flexibility is important.
Yes, small floor protectors or felt pads work well if you want the island to stay mostly fixed.
Alternatively, you can use casters with built-in, secure locking brakes that are very stable. This way, you can move the island easily with one hand and lock it safely in place.
Regarding the countertop: Solid wood looks fantastic, feels warm, and when well oiled, it also provides a nice, durable surface.
I used a 26mm (1 inch) thick beech wood board on top of a CAD computer-cut BESTA frame. It works great and looks stylish!
silis70 schrieb:
If casters are causing problems, would small floor protectors or another type of mobility be an option?
blaix schrieb:
Have you already checked whether the standard legs can support the weight of the countertop and occasional leaning?I want to add: If you choose casters, make sure to get high-quality ones with a high load capacity (at least 50 kg per caster) and locking brakes.
mintra schrieb:
Additional metal brackets increase stability.I can confirm that; the brackets noticeably prevent wobbling. This is especially important for an island, where work is often done from multiple sides.
If you glue or screw the components together, you can create a very solid unit.
