ᐅ How can I use IKEA BESTA as a shoe cabinet with ventilation?
Created on: 21 Jan 2024 08:12
Hausar
Hausar
21 Jan 2024 08:12
Hello everyone, I am planning to convert my IKEA Besta cabinet into a shoe storage unit, but I have concerns about ventilation.
The Besta is basically designed as a storage system for various items, but not specifically for shoes. In my opinion, shoes need continuous airflow to release moisture and prevent odors.
How could I best modify or use the Besta so that it functions as a shoe cabinet with adequate ventilation?
Maybe someone knows clever solutions, whether by drilling holes, installing ventilation grilles, using special inserts, or other tricks? It would also be helpful to know which materials are suitable to avoid mold or musty smells.
Thank you in advance for your advice!
sanjon
21 Jan 2024 08:45
Simply drill ventilation holes into the side walls and maybe install ventilation grilles. This ensures air circulation. Alternatively, place it on feet so that air can enter from below.
sifope
21 Jan 2024 09:10
Interesting approach, but is that really enough?
Ventilation holes are helpful, but you should also consider how strong the airflow inside the room is. Small holes alone might not provide enough draft to effectively remove moisture.
Have you thought about whether passive ventilation is sufficient, or if you might need an active system with fans or at least a completely different setup? And what about odor control through circulating air? This is often a weak point in shoe cabinets.
Hausar
21 Jan 2024 10:23
Thank you for the suggestions so far.
@sifope: Your idea about active fans is interesting, but I have not planned a dedicated power source at that spot in the BESTA. Passive ventilation would be preferred for aesthetic and practical reasons.
Could it help to replace the original shelves in the BESTA with shelving made of more breathable material (for example, wire shelves or perforated panels)? That way, air could circulate better between the shoes.
Or is there any experience with the combination of built-in units and ventilation openings?
Josefane
21 Jan 2024 11:17
sifope schrieb:
Have you considered whether passive ventilation is sufficient, or if you might need an active system with fans or at least a completely different setup?
That is really the key issue. Passive ventilation works well if the closet is located in an area that is already well-ventilated. Otherwise, it is usually not enough.
I would not underestimate the issue of moisture and mold growth. It might be worthwhile to integrate small battery-powered or solar-powered fans if there is a window nearby.
Otherwise, the best passive solution will be a combination of perforated side panels, slatted shelves, and some clearance from the floor. Important: make sure shoes are thoroughly dried before storing them.
U
usJamie
21 Jan 2024 13:02
Using grating or wire mesh flooring is a proven method.
Otherwise, be sure to install multiple ventilation grilles on the front and sides.
The BESTA is durable enough to handle this well.
