Created on: 25 Nov 2015 10:27
Koempy
I'll start right away.
Before March 2014:
After May 2015:
RobsonMKK13 Oct 2017 19:05
The screed has been installed since Monday:
Interior view of an unfinished hallway: walls, loose cables, door at the end leading outside
Hallway looking toward the main entrance
Unfinished interior with large glass sliding doors leading outside; construction site and earthworks visible.
View into the dining area
Empty unfinished room at the construction site with rough plaster walls, electrical outlets, window on the right.
TV and lounge area
Empty renovation room with open glass doors, visible wall connections, and construction cables on the floor.
Kitchen
Room under construction: plastered walls, exposed cables, wall sockets, blue floor protection.
Bedroom
Unfinished interior with two floor-to-ceiling windows, raw floor, cables, view outside.
View into one of the children's rooms (fall protection is already installed)
11ant13 Oct 2017 19:18
And when were the photos taken? It looks uneven (?)
RobsonMKK13 Oct 2017 19:41
The photos are from yesterday, and the waviness is misleading—it’s caused by the spreading process. The surface is completely level.
truce13 Oct 2017 19:48
Hygrometer installed?
Or just open the windows every few hours?
Ours is probably arriving in the next few weeks. Do we need a dehumidifier?
The heat pump won't be installed for another 1-2 months. Until then, it has to dry without underfloor heating :-/
RobsonMKK13 Oct 2017 19:55
We ventilate the house 2-3 times a day. I believe this is the only sensible approach at the beginning. After 3 weeks, the heating is supposed to start... we’ll see.
Nordlys
13 Oct 2017 20:32
Initially, only fresh air should be allowed on the screed. No heating or dehumidifiers. It needs to dry gently to avoid curling. After two to three weeks, more intensive drying methods can be applied. Karsten
