sirhc schrieb:
We are getting a fairly large / powerful unit with a corresponding RPM. The unit will be placed in the attic. I want to have rubber mats underneath to reduce vibrations. I hope that will be enough to prevent noise disturbances in the bedrooms. Otherwise, more complex decoupling will have to be done afterwards... Intuitively, I would suspect that this won’t be sufficient... Maybe you can get some advice from the system manufacturer? Our neighbors solved the "problem" of controlled residential ventilation in the attic with a concrete ceiling (bungalow). The construction company had done a similar setup before, but with a wooden ceiling, and the homeowner was not completely satisfied.
Robbaut schrieb:
Intuitively, I would guess that this is not enough... Maybe you can get some tips from the manufacturer of the system? Our neighbors solved the "problem" of controlled residential ventilation in the attic with a concrete ceiling (bungalow). The construction company had implemented the same setup before, but with a wooden ceiling, and the client was not 100% satisfied.What I originally wanted to say: The unit is relatively large/powerful and operates at a lower speed compared to smaller units. For a concrete ceiling, of course, it’s already too late.
The feedback from @Saruss reassures me for now. In our case, the layers from top to bottom should be as follows:
- Controlled residential ventilation main unit
- Rubber mat
- 22 mm (about 0.9 inches) OSB boards as storage floor
- 200 mm (about 8 inches) collar beams with 200 mm (about 8 inches) stone wool insulation between the collar beams
- Battens
- Counter battens
- Cladding (probably one layer of OSB and underneath another layer of gypsum board)
- Previous
- 1
- 2
- 3
- 10
- 20
- 30
- 40
- 50
- 60
- 70
- 72
- 73
- 74
- 75
- 76
- 77
- 78
- 79
- 80
- 81
- 82
- 90
- 100
- 110
- 120
- 130
- 140
- 150
- 160
- 170
- 180
- 190
- 200
- 210
- 220
- 230
- 240
- 250
- 260
- 270
- 280
- 290
- 300
- 310
- 320
- 330
- 340
- 350
- 360
- 370
- 380
- 390
- 400
- 410
- 420
- 430
- 440
- 450
- 460
- 470
- 480
- 490
- 500
- 510
- 520
- 530
- 540
- 550
- 560
- 570
- 580
- 590
- 600
- 610
- 620
- 630
- 640
- 650
- 660
- 670
- 680
- 690
- 700
- 710
- 720
- 730
- 740
- 750
- 760
- 770
- 780
- 790
- 800
- 810
- 820
- 830
- 840
- 850
- 860
- 870
- 880
- 890
- 900
- 910
- 920
- 930
- 940
- 950
- 960
- 970
- 980
- 990
- 1000
- 1010
- 1020
- 1030
- 1040
- 1050
- 1060
- 1070
- 1080
- 1090
- 1100
- 1110
- 1120
- 1130
- 1140
- 1150
- 1160
- 1170
- 1180
- 1190
- 1200
- 1210
- 1220
- 1230
- 1240
- 1250
- 1260
- 1270
- 1280
- 1290
- 1300
- 1310
- 1320
- 1330
- 1340
- 1350
- 1360
- 1370
- 1380
- 1390
- 1400
- 1410
- 1420
- 1430
- 1440
- 1450
- 1460
- 1470
- 1480
- 1490
- 1500
- 1510
- 1520
- 1530
- 1540
- 1550
- 1560
- 1570
- 1580
- 1590
- 1600
- 1610
- 1620
- 1630
- 1640
- 1650
- 1660
- 1670
- 1680
- 1690
- 1700
- 1710
- 1720
- 1730
- 1740
- 1750
- 1760
- 1770
- 1780
- 1790
- 1800
- 1810
- 1820
- 1830
- 1840
- 1850
- 1860
- 1870
- 1880
- 1890
- 1900
- 1910
- 1920
- 1930
- 1940
- 1950
- 1960
- 1970
- 1980
- 1981
- 1982
- 1983
- Next
