Created on: 25 Nov 2015 10:27
Koempy
I'll start right away.
Before March 2014:
After May 2015:
face2616 Jan 2020 10:40
Grantlhaua schrieb:
You’re asking me questions. The rough construction dimension was 1m (3.3 ft), then minus the plaster, and how much the steps protrude I can measure for you this evening if I remember.
Haha, I didn’t mean the width. It would be really great if you could measure. I meant the height of a step and the depth—that is, how many centimeters (inches) are available as the tread depth.
neubau2019
16 Jan 2020 10:40
Grantlhaua schrieb:
Since @matte1987 asked again for photos from our construction site
Nice staircase, what are you planning to use as a railing?
tumaa
16 Jan 2020 10:44
I believe a few photos will do the thread some good again.
Update: without scaffolding
Shell of a multi-story brick house with open window openings, sand piles in front.
Two-story brick building under construction with large window openings, construction debris on the ground.
Two-story brick house under construction with open window and door openings; a ladder in front.
Exterior view of an unfinished brick house with windows and transparent protective foil on the wall.
Unfinished two-story brick house on construction site with round concrete forms and building materials.
New build construction site: brick wall with vertical downpipe, construction equipment and waste in the yard.
11ant16 Jan 2020 11:00
denz. schrieb:
Now we only have 2 joints. If you can call them that. The panels are placed edge to edge.
The question remains: what would be the disadvantage or reason to avoid traditional joints (i.e., filled gaps at the seams)?
Grantlhaua
16 Jan 2020 11:01
face26 schrieb:
Haha, I didn’t mean the width. It would be really helpful if you could measure. I meant the height of a step and the depth—that is, how many centimeters (inches) are available as the tread dimension.
Oh, I hope I remember.
neubau2019 schrieb:
Nice staircase, what are you planning to use as the railing?
If only we knew...
denz.
16 Jan 2020 11:09
The question remains, what would be negative or undesirable about classic joints (that is, filled gaps at the seams)?
Appearance
