Traumfaenger22 Apr 2019 23:38Snowy36 schrieb:
The reason he doesn’t offer maintenance services is probably because nowadays you can maintain it yourself... what maintenance would there be for a mechanical ventilation with heat recovery system? If you check, clean, and disinfect the intake point, outdoor air ducts, heat exchanger, fan, filter chamber, distribution box, supply and exhaust air ducts, as well as all valves yourself, that’s perfectly fine. Depending on the component, maintenance is required not annually but at longer intervals. I can just as well maintain the electrical backdraft damper myself if I have the time and feel like going downstairs. But I’m not keen on that ))
Please explain exactly what the plumber services on the fan of the controlled residential ventilation system or on the heat exchanger? What exactly does he do at the distribution box?
We can clean the supply and exhaust air ourselves (Erlus), and according to his own statement, the only thing the plumber would do is change the filters on the unit itself and at the outlets, etc.… and I can do that myself…
guckuck2 schrieb:
See the maintenance manual. Changing a filter or wiping down a housing isn’t rocket science Exactly... so why would anyone sign a maintenance contract? I understand it for the air-to-water heat pump because of the warranty... or maybe for the backflow preventer due to insurance, perhaps...
Grobmutant23 Apr 2019 13:49@hampshire
Oh, interesting. I didn’t expect anyone to have actually installed solar roof tiles yet, apart from Elon Musk.
I thought they were still very expensive. Would you mind sharing the price or the extra cost compared to regular photovoltaic panels?
A close-up photo would also be great.
hampshire schrieb:
The bricks are on the house. Each of the two roofs has two areas covered with solar roof tiles. [...]
Traumfaenger schrieb:
Were emergency overflow drains already mandatory back then? Their purpose is to divert water if the downspout becomes clogged. If even a trickle ever comes out of an emergency overflow (located near every downspout), all alarm bells should go off.Here we also have a hidden channel drain!
Traumfaenger, do you have a picture of your emergency overflow? Do you have a gutter heating system installed? Can you hear dripping sounds from the downspout?
- Previous
- 1
- 2
- 3
- 10
- 20
- 30
- 40
- 50
- 60
- 70
- 80
- 90
- 100
- 110
- 120
- 130
- 140
- 150
- 160
- 170
- 180
- 190
- 200
- 210
- 220
- 230
- 240
- 250
- 260
- 270
- 280
- 290
- 300
- 310
- 320
- 330
- 340
- 350
- 360
- 370
- 380
- 390
- 400
- 410
- 420
- 430
- 440
- 450
- 460
- 470
- 480
- 490
- 500
- 510
- 520
- 530
- 540
- 550
- 560
- 570
- 580
- 590
- 600
- 610
- 620
- 630
- 640
- 650
- 660
- 670
- 680
- 690
- 700
- 710
- 720
- 730
- 740
- 750
- 760
- 770
- 780
- 790
- 800
- 810
- 820
- 830
- 840
- 850
- 860
- 870
- 880
- 890
- 900
- 910
- 914
- 915
- 916
- 917
- 918
- 919
- 920
- 921
- 922
- 923
- 924
- 930
- 940
- 950
- 960
- 970
- 980
- 990
- 1000
- 1010
- 1020
- 1030
- 1040
- 1050
- 1060
- 1070
- 1080
- 1090
- 1100
- 1110
- 1120
- 1130
- 1140
- 1150
- 1160
- 1170
- 1180
- 1190
- 1200
- 1210
- 1220
- 1230
- 1240
- 1250
- 1260
- 1270
- 1280
- 1290
- 1300
- 1310
- 1320
- 1330
- 1340
- 1350
- 1360
- 1370
- 1380
- 1390
- 1400
- 1410
- 1420
- 1430
- 1440
- 1450
- 1460
- 1470
- 1480
- 1490
- 1500
- 1510
- 1520
- 1530
- 1540
- 1550
- 1560
- 1570
- 1580
- 1590
- 1600
- 1610
- 1620
- 1630
- 1640
- 1650
- 1660
- 1670
- 1680
- 1690
- 1700
- 1710
- 1720
- 1730
- 1740
- 1750
- 1760
- 1770
- 1780
- 1790
- 1800
- 1810
- 1820
- 1830
- 1840
- 1850
- 1860
- 1870
- 1880
- 1890
- 1900
- 1910
- 1920
- 1930
- 1940
- 1950
- 1960
- 1970
- 1980
- 1981
- 1982
- 1983
- Next
