Created on: 25 Nov 2015 10:27
Koempy
I'll start right away.
Before March 2014:
After May 2015:
hampshire
9 Apr 2019 21:54
LaloBau schrieb:
There’s progress here as well. Tomorrow, the foundation slab is scheduled to be poured...
Foundation slabs often look surprisingly small at first—don’t be alarmed. Once the surrounding walls are up, it feels much larger.
A great milestone in the construction process!
Mottenhausen
10 Apr 2019 08:04
Here is an interesting update on our construction progress (ground floor ceiling just before pouring). What a busy scene.
Shell construction with steel reinforcement, green pipes, and formwork; city in the background.
Q
quisel
10 Apr 2019 08:45
Mottenhausen schrieb:
Here’s an interesting update from our construction site (the ground floor ceiling just before pouring). What a busy scene.
Did you install the electrical cables inside conduit pipes?
pffreestyler
10 Apr 2019 08:55
Slava_S schrieb:
Quite a lot has happened in the last two weeks.
The screed was installed as planned on March 28th, and the heating-up process has been running for about a week now. The tiler has already started work on the showers and walls.
Outside, the top coat plaster has been applied, the roof overhang has been painted, and by early next week at the latest, the final coat of paint should go on and hopefully the scaffolding will be removed.
The whole project is gradually taking shape.
What kind of screed do you have? o.O We have to wait three weeks before we can start heating, and the tiler won’t begin until at least three weeks after that.
Lumpi_LE
10 Apr 2019 10:02
quisel schrieb:
Did you install the electrical wiring inside conduit pipes?
In a cast-in-place concrete ceiling, the electrical cables definitely need to be run through conduit pipes...
Slava_S
10 Apr 2019 11:06
pffreestyler schrieb:
What type of screed do you have?
The screed used on the floors is Thermorapid 2.0. It can be walked on after one day and is ready for covering after two weeks.
In the showers, this screed was not installed. Instead, the tiler applies a different screed there, which allows them to start even earlier.
