Loads schrieb:
Today, our underfloor heating was installed.
I noticed a large gap in the upper hallway.
No idea if this could be correct.
But I’m rather doubtful, right?
I assume the hallway does not have its own heating circuit. The pipes run to the individual rooms, so the gap should be fine.
I find the gap in image 3 at the bottom right more unusual. Also, the pipes are very close together there.
We have a separate heating circuit with a thermostat both in the upstairs and downstairs hallways, and the pipes run close together everywhere. With tiled floors, you can immediately feel the warmth from the underfloor heating, whereas the large area on your side remains cold, which is uncomfortable for walking barefoot.
Sabine
Sabine
Curly schrieb:
We have a separate heating circuit with a thermostat in the hallway both upstairs and downstairs But that doesn’t necessarily apply to @Loads. And who says the hallway will be tiled? In the upstairs hallway, the tiles won’t be freezing cold either, since it’s an interior area and will be at least room temperature. Having a separate heating circuit for the interior hallway shown would be overkill. The supply pipes running to the rooms will already provide more than enough heat, and the valves would almost always be closed. You could at most distribute the pipes more evenly to avoid temperature differences.
I also find the loophole at hip height quite interesting.
- Previous
- 1
- 2
- 3
- 10
- 20
- 30
- 40
- 50
- 60
- 70
- 80
- 90
- 100
- 110
- 120
- 130
- 140
- 150
- 160
- 170
- 180
- 190
- 200
- 210
- 220
- 230
- 240
- 250
- 260
- 270
- 280
- 290
- 300
- 310
- 320
- 330
- 340
- 350
- 360
- 370
- 380
- 390
- 400
- 410
- 420
- 430
- 440
- 450
- 460
- 470
- 480
- 490
- 500
- 510
- 520
- 530
- 532
- 533
- 534
- 535
- 536
- 537
- 538
- 539
- 540
- 541
- 542
- 550
- 560
- 570
- 580
- 590
- 600
- 610
- 620
- 630
- 640
- 650
- 660
- 670
- 680
- 690
- 700
- 710
- 720
- 730
- 740
- 750
- 760
- 770
- 780
- 790
- 800
- 810
- 820
- 830
- 840
- 850
- 860
- 870
- 880
- 890
- 900
- 910
- 920
- 930
- 940
- 950
- 960
- 970
- 980
- 990
- 1000
- 1010
- 1020
- 1030
- 1040
- 1050
- 1060
- 1070
- 1080
- 1090
- 1100
- 1110
- 1120
- 1130
- 1140
- 1150
- 1160
- 1170
- 1180
- 1190
- 1200
- 1210
- 1220
- 1230
- 1240
- 1250
- 1260
- 1270
- 1280
- 1290
- 1300
- 1310
- 1320
- 1330
- 1340
- 1350
- 1360
- 1370
- 1380
- 1390
- 1400
- 1410
- 1420
- 1430
- 1440
- 1450
- 1460
- 1470
- 1480
- 1490
- 1500
- 1510
- 1520
- 1530
- 1540
- 1550
- 1560
- 1570
- 1580
- 1590
- 1600
- 1610
- 1620
- 1630
- 1640
- 1650
- 1660
- 1670
- 1680
- 1690
- 1700
- 1710
- 1720
- 1730
- 1740
- 1750
- 1760
- 1770
- 1780
- 1790
- 1800
- 1810
- 1820
- 1830
- 1840
- 1850
- 1860
- 1870
- 1880
- 1890
- 1900
- 1910
- 1920
- 1930
- 1940
- 1950
- 1960
- 1970
- 1980
- 1981
- 1982
- 1983
- Next
