Created on: 25 Nov 2015 10:27
Koempy
I'll start right away.
Before March 2014:
After May 2015:
ivenh0
2 Nov 2018 13:40
Multi-story house in shell construction with scaffolding and construction equipment on site
Tomorrow morning, the cables will be installed in the attic ceiling. On Monday, concreting will take place...
Z
Zaba12
2 Nov 2018 13:44
Considering that the foundation for the L-shaped blocks was only poured on October 16th, I am really satisfied with the construction progress.
Rohbau-Fundament mit blauer Dämmung in Baugrube und Leitern auf der Baustelle
Climbee2 Nov 2018 14:30
So, I was busy with other things last week, so I wasn’t very active here.
The reason:
Bride and groom with bridal bouquet on a construction site, shell construction and scaffolding in the background
(Of course, we had to take a photo on site )
But otherwise, a lot has happened:
The technical room is starting to get full; the system for heating (solar, photovoltaic, etc.) is almost complete. The descaling system and the large electrical cabinet, as well as the ventilation system, are still missing. However, I don’t have a picture of those.
Then we got a roof; only the counter battens are missing, and then finally the roof tiles will be installed:
Shell interior of an attic with OSB boards, wooden frame, and window opening
The carport is also almost finished (except for the cladding and, of course, the paving):
Construction site at the house with wooden beams, scaffolding, and stacked components
When the sun shines as nicely as it has the last few days, you can almost get a sense of space in the living room (and behind the tarp, it’s already nice and cozy warm):
Interior construction site with wooden frame structure, ongoing work, and workspace
The double casement window in the bathroom already has its frame:
Open wooden roof truss in shell construction with light shining through a roof opening
From the outside, it’s really starting to look like a house:
Construction site at the house with scaffolding, blue cover, and protective nets around the roof area
Now we’re just looking forward to the roof being fully finished. It’s already sealed, but the counter battens and the tiles are still missing.
Inside, the electrician is already hard at work. Hopefully, the interior walls will go up soon, then we will do another walk-through with our lighting designer to finalize the last lamps and lighting.
By the end of November/beginning of December, the windows should also be installed, and then there will be a topping-out celebration.
Z
Zaba12
2 Nov 2018 14:36
Climbee schrieb:
So, last week I was busy with other things, so I wasn’t very active here.
The reason:
(of course, we had to take a photo on site )
But a lot has happened otherwise:
The utility room is starting to fill up; the system for heating (solar, photovoltaic, etc.) is almost finished. Only the descaling system, the large electrical cabinet, and the ventilation system are still missing. I don’t have a picture of those yet.
Then we got a roof; only the counter-battening is left, and then the roof tiles will finally go on:
The carport is also almost complete (except for the cladding and, of course, the paving):
When the sun is shining as nicely as it has the past few days, you can almost get a sense of space in the living room (and it’s cozy and warm behind the tarp as well):
Now we’re just looking forward to the roof actually being finished. It’s already watertight, but the counter-battening and the tiles are still missing.
Inside, the electrician is already hard at work. Hopefully, the interior walls will be installed soon, after which we will do a walk-through with our lighting designer to finalize the last lamps and lighting fixtures.
By the end of November/beginning of December, the windows should be installed, and then we will celebrate the roof raising ceremony first.
Congratulations!
11ant2 Nov 2018 14:42
Climbee schrieb:
and then the topping-out ceremony is celebrated first
With wedding cake
Doesn't the groom get impatient if the threshold for carrying the bride over is not finished yet?
Climbee2 Nov 2018 14:50
With a wedding cake
Doesn't the groom get impatient if the threshold for carrying the bride across is not finished yet?
The bride wouldn’t want to put the groom through that, even with the nicest threshold.
Thank you for the congratulations!
