Created on: 25 Nov 2015 10:27
Koempy
I'll start right away.
Before March 2014:
After May 2015:
Curly
2 Aug 2018 09:36
dertill schrieb:
It doesn’t have to apply to @Loads. And who says the hallway will be tiled? In the upstairs hallway, the tiles don’t get ice-cold either, since it’s an interior space and stays at least room temperature.
No one said the hallway will be tiled, which is why I mentioned you can tell with tiles whether there’s a heating pipe underneath or not. “Ice-cold” shouldn’t be taken literally, but for me, room temperature still feels cold on a tiled floor. With underfloor heating, it feels noticeably warmer, which is quite a difference.
Sabine
E
Eldea
2 Aug 2018 10:06
What strikes me more is the uneven window arrangement (standard and arrow slit-style, practically in the same corner) in picture 2. Where the underfloor heating loops in the hallway apparently "are missing," you would probably only trip over a sleeping cat anyway. No icy draft will form there.
Oh my, I hadn’t even thought about the cats with that. Although, they’re always in the way anyway.
E
Eldea
2 Aug 2018 10:09
Today we continue with the installation of the kitchen.
Kitchen under construction: white base cabinets on casters, window with roller shutters, gray walls
Unfinished kitchen with white base cabinets on casters, gray walls, large window with blinds.
Curly
2 Aug 2018 10:16
The color on the wall including the edge looks like ours. Is this the shade "Roofs of Paris"?
Sabine
Loads
2 Aug 2018 10:50
I just spoke with the heating installer.
He says that the installation is specified by the heating system manufacturer.
However, he will double-check and get back to me.
The flooring here will be parquet.
The other gap is the transition between the living room and the hallway.
There might still be a door installed here (I haven’t decided yet).
There are no cats here.
I had imagined the firing slit to be somewhat larger,
but it is what it is and doesn’t really bother me.
It is located between the countertop and the wall cabinets in the kitchen.
E
Eldea
2 Aug 2018 11:35
Curly schrieb:
The color on the wall including the edge looks like ours, is that the shade "Roofs of Paris"?
Sabine
It's a Sto paint; they don't use such romantic names for their colors.
It's simply called 16284.
