Created on: 25 Nov 2015 10:27
Koempy
I'll start right away.
Before March 2014:
After May 2015:
AxelH.4 Jan 2018 18:49
What do you have opposite you there: a community center?
Almost correct. What you see diagonally opposite in the pictures is a special needs school. The community center is located directly opposite as well (not visible in the picture), but significantly lower down. And then there is also the Protestant church next to the community center.
Axel
AxelH.5 Jan 2018 19:09
Dear friends of house building,
After sharing a photo of the exterior walls in the morning light yesterday before work started (Post #1714), today I can show the now completed interior walls in the evening light.
Axel
Unfinished white log house on a slope, window openings visible, construction equipment in the background
RobsonMKK5 Jan 2018 19:26
I’m responding with a bit of fine-tuning done myself:
Construction room with white tiled floor, tile spacers visible, exposed brick wall on the right.
Finished storage room
Dark square floor tiles being installed, tile spacers visible, construction area.
Started utility room
Bright room with white walls and colorful striped wall paneling at the bottom; glass door.
Small room with pastel violet upper walls, colorful striped paneling at the bottom, door with roller shutter.
Completed wallpapered and painted princess room
Alex85
5 Jan 2018 19:36
It seems that tiling comes more naturally to you than wallpapering.
11ant5 Jan 2018 19:42
RobsonMKK schrieb:
Fully wallpapered and painted princess room
The colorful barcode pattern is a bit too psychedelic for me
bau.herr5 Jan 2018 21:18
Modern white kitchen with island, dark countertops, oven and sink by the window.
The kitchen arrived today.
