Created on: 25 Nov 2015 10:27
Koempy
I'll start right away.
Before March 2014:
After May 2015:
kati133721 Sep 2020 16:37
You are right, I hadn’t thought about the baseboard yet. Maybe he did it intentionally for that reason.
hausnrplus2521 Sep 2020 18:43
kati1337 schrieb:
You are right, I hadn’t thought about the baseboard yet. Maybe that’s why he did it intentionally.
Good point! Still, the edge would be there at the top, and a baseboard should be thicker, right?
We’ve already had this discussion: baseboards “all around the staircase.” Tricky topic ^^
kati133721 Sep 2020 18:50
hausnrplus25 schrieb:
Good point! Still, the edge would be up there, and baseboards can be thicker, right?
We've had this conversation before: baseboards “all around the staircase.” Tricky topic ^^
Yeah, I’m not sure what to think about it either.
I’ll wait for the final inspection. The argument from earlier, that other areas in the house could suffer if the stair installer has to come back, is definitely true. The wallpaper and paint were already a bit damaged during the initial staircase installation.
Bookstar
21 Sep 2020 20:50
The post really doesn't bother me at all, and criticizing it is completely over the top.
kati133721 Sep 2020 22:38
Well, I wouldn't say it's overly exaggerated. It’s asymmetrical, and the entire handrail leading there is crooked—you can clearly see that.
I've often heard that a centimeter (0.4 inches) doesn’t matter much in construction, but I don’t quite agree with that. Plans are binding.
Tarnari21 Sep 2020 22:42
If you don’t like it or if it does not match the agreement, then speak up.
Anything else will only cause you frustration. Especially because the wrong post caps are used.
