Created on: 25 Nov 2015 10:27
Koempy
I'll start right away.
Before March 2014:
After May 2015:
hampshire
26 Feb 2020 15:09
Fire can be used both indoors and outdoors. For outdoors, we are now planning something like the one shown in the picture from the Lindlar Grauwacke Manufaktur.
Round fire pit with burning wood logs, stone seating wall with cushions.
Climbee26 Feb 2020 15:52
Also nice. We have fallen for a fire pit from gartenmetall:
Person kneeling in the garden next to a square fire basket, flames roaring.
Rust-colored fire basket with flames on a modern stone terrace, stairs in the background.
tumaa
26 Feb 2020 16:07
Should we start a fire pit thread?
Brick barbecue chimney with open fire; sausages on a grill, wine bottle on the left, plate and knife
hampshire
26 Feb 2020 16:38
Climbee schrieb:
…heated in the morning, then it has to burn down completely before it can be closed. If we come home late in the evening, it has already cooled down, and it takes about an hour before it warms up again.
This handling of a masonry stove is not necessary. There are quite modern devices available. For example, Ortner offers a burn control system. It measures temperatures with sensors and regulates the burn in multiple phases. This not only achieves optimal energy use but also a clean burn (provided good firewood is used). Of course, the stove can also be operated manually without the electronics – it would be ridiculous if a masonry stove didn’t work during a power outage! Loading about 10 kg (22 lbs) of beech wood is sufficient to heat our house comfortably for 24 hours when the outside temperature is 0°C (32°F).
Climbee26 Feb 2020 16:42
Tumaa, is that your fire pit? Is that a slab made of polished concrete?
Do you have any more photos of it?
Bookstar
26 Feb 2020 17:22
hampshire schrieb:
This way of operating a masonry heater is not necessary. There are certainly modern units available. Ortner, for example, offers a burn control system. It uses sensors to measure temperatures and controls the burn in several phases. This not only ensures optimal energy use but also a clean burn (assuming good firewood). Of course, you can also operate the stove manually without the electronics – it would be ridiculous if a masonry heater didn’t work during a power outage! Loading about 10 kg (22 lbs) of beech wood is enough to heat our house comfortably for 24 hours at 0°C (32°F) outside temperature.
I admit I am clueless. But how do you distribute the heat throughout the house? With a standard tiled or wood-burning stove, a simple door is enough, and no heat reaches the adjoining room. That’s why we have an opening with a grille in the living area. Still, in the upper floor, no heat arrives.
How is this handled with a masonry heater?
