Created on: 25 Nov 2015 10:27
Koempy
I'll start right away.
Before March 2014:
After May 2015:
Arifas25 May 2018 13:48
Wow, there’s a lot going on here [emoji847]. Great pictures – beautiful houses [emoji4]
For us, the scaffolding has (for now) been removed so backfilling can be done behind the house, and the plasterers are applying the interior plaster.
Empty construction room with blue and white ceiling foil, two windows, tools on the floor.
Two-story house under construction with windows, pink facade tape, and gravel ground in front
Two-story shell house with gray exterior wall, windows, pink insulation strips, and construction ground in front.
haydee
25 May 2018 13:58
Arifas is making good progress with your project.
11ant25 May 2018 14:20
Arifas schrieb:
For now, the scaffolding has been removed so that the area behind the house can be backfilled, and the plasterers are applying the interior plaster.
Neat Obelix foil on the ceiling
munger71
25 May 2018 18:49
Dark floor tiles in the bathroom area of a construction project with a drain edge.
Small, empty room with wet dark gray tiled floor and water stains.
Tiler’s workspace with white floor, tile cutter, blue tools, and red basket.
Progress is being made on our end as well...
R.Hotzenplotz
25 May 2018 19:38
People working in unrelated fields often have overly romantic ideas about how appealing their house would look even without any finishing. Still, it will last a hundred years.
No, I don’t care how it looks beneath the facade. If anything, I would consider insulation properties and such. But that’s not an issue in this case. So, all good.
E
Eldea
25 May 2018 20:16
Being sick and unable to go to the construction site [emoji19] The plan was to have all the storage surfaces covered with the floor tile. This needs to be changed. It’s just all too white for me [emoji85]
Bathroom under construction: gray floor tiles, shower on the left, bathtub on the right, spirit level placed there.
Bathroom under construction: white tiles, bathtub filled, spirit level on gray tiled floor.
