Created on: 25 Nov 2015 10:27
Koempy
I'll start right away.
Before March 2014:
After May 2015:
Z
Zaba12
13 Aug 2019 10:45
opalau schrieb:
With such a large lampshade, I would always expect a conflict between "There is no glare" and "I can still see the person sitting across the table." Is there really an optimal height that achieves both?
Yes, that would be the mentioned 60-70cm (24-28 inches), depending on the depth of the lampshade.
O
Otus11
13 Aug 2019 10:48
And then, as mentioned, there is also the head-bump factor when standing up...
Edit: For some models, there are retrofit diffusers available to reduce glare.
Curly
13 Aug 2019 10:53
We have these black metal frame lamps above the dining table, so the bulbs are completely visible and there is no glare at all. Maybe your lamps are just too bright? At 60-70cm (24-28 inches) above the table, you can’t really see who is standing on the other side when seated, and I think the bulbs will still be visible since the lampshade is very wide open. When setting or wiping the table, you’re also likely to bump your head on them.
Sabine
opalau13 Aug 2019 10:54
Curly schrieb:
We have those black metal frame lamps above the dining table, so the bulbs are completely visible and there is no glare at all. Maybe your lamps are just too bright? At 60–70cm (24–28 inches) above the table, you can’t see who is standing on the other side while sitting, and I think you would still see the bulbs since the lampshade is so widely open. When setting or wiping the table, you might also bump your head on it.
Sabine
That’s exactly what I meant. If the lamp hangs so high that I can look underneath, then with such a large shade I can also look inside and will be blinded by the bulbs.
O
Otus11
13 Aug 2019 11:08
With a fixture featuring a long body (and a wider opening at the bottom), there is no glare, even though it is hung fairly high in our space. It is also available with a long suspension cable, 5 or 6 meters (16.4 or 19.7 feet). The top is open, which nicely showcases the cable. Ours has a 21 W LED bulb, dimmable. A diffuser can be added afterward.
Lightyears Caravaggio P4 (E27) (not fully visible here at the top)
Solveigh
14 Aug 2019 13:59
The scaffolding is up. The timber house will be delivered next week. We are looking for backfill material and still need about 2000m³ (70,600 ft³).
Construction site with concrete foundations and scaffolding, at the lakeside with boats and mountains in the background.
