Created on: 25 Nov 2015 10:27
Koempy
I'll start right away.
Before March 2014:
After May 2015:
benediktr
9 Mar 2021 18:59
rick2018 schrieb:
Looks neat.
Is that all the LAN you have? Seems very little to me.
Yes, that's all the LAN. There are a total of 22 CAT7 cables. Additionally, there are surface-mounted cables for the heat pump and the IP interface for the bus system. So, by chance, a 24-port switch fits perfectly.
AMNE3IA10 Mar 2021 16:17
The shower area is finally complete 🙂.
The recessed spots in the niche plus ceiling downlights provide general lighting.
An LED strip in the niche along with two wall and ceiling lights each create a cozy atmosphere.
Large walk-in shower with gray tiles; niche with three downlights, rain showerhead, and hand shower.
Modern walk-in shower with gray tiles, ceiling-mounted rain showerhead, hand shower, and illuminated niche.
hampshire
10 Mar 2021 17:29
Which wall tiles are these? Bone Rec?
AMNE3IA10 Mar 2021 19:37
I just had to check myself in the attic.
They are Castelvetro Always Bianco CAW48R1.
benediktr
10 Mar 2021 20:13
AMNE3IA schrieb:
The shower area is finally finished 🙂.
The recessed spotlights in the niche plus ceiling downlights as the main lighting.
LED strip in the niche with two wall and ceiling lights each for cozy lighting.
Very nice. Planning something similar in terms of appearance. I have two questions:
How did you install the LED strip, where is it connected, and how was the waterproofing handled?
Which faucet manufacturer and color combination is that? We have chosen the Brushed Black series from Hansgrohe. It looks similar.
AMNE3IA10 Mar 2021 21:05
benediktr schrieb:
Very stylish. Our design is similar in appearance. I have two questions:
How did you install the LED strip, where is it clamped, and how did you ensure water protection?
Which faucet manufacturer and color combination is that? We chose the Brushed Black series from Hansgrohe. It looks similar.
The LED strip is embedded in a flexible, coated tube (something like silicone). This tube is inserted into a stainless steel tile profile and fits in like it’s cast in place. You can cut the tile profile to any length. The LED strip can be cut every 25mm (1 inch).
Our niche is masonry-built, and cables run behind it (I pulled the cables before the niche was built) to the attic (see photos). In the attic, they’re connected to a transformer. So, the shower/wet area only has 12 volts. Definitely a fun project until it was finished 😀
Manufacturer: Grohe
Series: Atrio
Color: Supersteel
White brick wall with a curved metal pipe, loose cable conduits, and blue notes on the wall.
Installation terminals with orange covers, blue and brown cables on a metal frame.
Metal plate with two orange connectors and blue/brown cables on a wall.
Sketch on concrete wall: LED strip plan with cables and markings.
