Created on: 25 Nov 2015 10:27
Koempy
I'll start right away.
Before March 2014:
After May 2015:
I
icandoit
15 Feb 2021 19:39
Schimi1791 schrieb:
... and the clear width?
106 cm (42 inches)
Nida35a15 Feb 2021 21:56
The move was through the patio door,
2-leaf without a central mullion, clear width 1.7m (5 ft 7 in)
Schimi179116 Feb 2021 17:53
2-leaf without a mullion, clear width 1.7m (5.6 feet)
It was the same for us 🙂
After consulting with the craftsmen, they will widen our door opening by 4 cm (1.6 inches). This way, the door will be almost as large as before.
Nida35a16 Feb 2021 18:03
The door can be adjusted to fit the door opening, as long as the additional cost does not double the price of the door, which is acceptable.
Schimi179116 Feb 2021 21:19
The finishing work will be somewhat more complex, as baseboards, among other things, also need to be modified. The cost should still remain within the (door) frame.
benediktr
20 Feb 2021 21:11
Another small milestone reached. Our interior staircase has finally arrived. It was a tough decision to make.
Metal staircase with open wooden steps in unfinished interior, raw masonry and window on the right.
Unfinished interior with steel staircase, rough walls, cables on the floor and large window to the outside.
My spotlights also caused sleepless nights because I had to measure, drill, and plaster them without the staircase in place. I calculated the exact positions based on the plan and repeatedly measured from the zero line. Conclusion: The effort was worth it.
Wooden staircase leaning diagonally against white block wall in shell construction, orange extension cable bottom right.
