Created on: 25 Nov 2015 10:27
Koempy
I'll start right away.
Before March 2014:
After May 2015:
Solveigh
29 Oct 2019 19:21
Wonderful house @opalau !!
Climbee30 Oct 2019 07:31
To me, it would be a bit too dark – but it might look completely different once there is greenery around it.
V
vx220
30 Oct 2019 07:38
The plasterers will finish their work today, and on Monday the screed installer will start installing the insulation. The plan is to apply the screed on Friday of next week.
Innenraum einer Baustelle: Holzgeländer über Öffnung, rechts Metallgerüst, Arbeiter unten links.
j.bautsch
30 Oct 2019 09:46
@opalau could you please post more pictures of the "stairwell"? I also want a half-turn landing concrete staircase. However, I usually plan it to be open to the "lower" side of the room because I’m worried it might otherwise become a narrow, dark space. That’s why example pictures would be very helpful to me.
opalau30 Oct 2019 09:55
Certainly, @j.bautsch. I’ve attached photos from different construction phases for you. The bottom two steps are open on one side, and the step width is 1.10m (3 ft 7 in). Together with the large windows, I find it very pleasant.
Unfinished concrete staircase under construction with temporary wooden handrail and steel support
Unfinished construction site: concrete stairs, scaffolding poles, and construction lumber in front of a wall.
Construction site – man in work clothes standing at the top of a concrete staircase in an unfinished interior.
Unfinished site staircase made of wood next to a concrete wall, clamps, purple foam block.
Unfinished interior made of concrete blocks, stairs on the right, red electrical outlets on the walls, no railing
Interior of a construction site: unplastered concrete block walls, staircase on the left, electrical installations.
Steps of a site staircase, dusty; ladder leaning on the upper window, light coming from outside.
Floor plan of an interior space with hallway, stairs, and elevator; detailed views.
j.bautsch
30 Oct 2019 12:07
Thank you very much, also for the measurements, that really helps me a lot. It doesn’t actually look that "holey." Maybe this will open up other floor plan possibilities for us.
