Find a secluded spot in your garden and plant everything directly into the soil there. Most plants can be easily relocated later. Anything that doesnât survive the winter can go on the compost. Plastic tunnels donât work well.
We did this with our âhalfâ garden⊠we brought many cuttings from the old garden. Some plants I only moved to the appropriate place two years later.
Myrna_Loy16 Nov 2022 10:48Steffi33 schrieb:
Choose a secluded corner in your garden and plant everything directly into the ground there. Most plants can be easily relocated later. Anything that doesnât survive the winter can go on the compost pile. Plastic tunnels are not very effective.
We did it this way with our âhalfâ garden⊠we brought many cuttings from the old garden. Some I only moved to the right spot two years later.This is actually best for the plants. The biggest risk for potted plants is not freezing, but drying out or waterlogging. Proper watering of pots in winter is tricky; itâs better to plant them relatively close together in a bed.M
motorradsilke16 Nov 2022 13:39Steffi33 schrieb:
Find a secluded spot in your garden and plant everything directly in the ground there.. most of it can be easily relocated later.
I did the same during the construction phase and the first winter afterwards. It works perfectly.M
Myrna_Loy16 Nov 2022 14:41haydee schrieb:
Holes at the bottom of the pot help prevent waterlogging; they should be there anyway.
That's obvious. In winter, most plants need much less water; otherwise, the roots will rot. Leaves donât absorb water and shoots donât grow either. I find it almost impossible to give the right amount of water. On top of that, there are the changing conditions under the plastic cover? I donât think much would survive with me.Similar topics
