ᐅ Dishwasher front panels
Created on: 26 Mar 2014 11:26
Sektionschef
Hello
Has anyone here already looked into the installation options for dishwasher fronts in the new Metod kitchen system? I have spent some time researching this topic and would like to share my current findings with you:
As I understand it, IKEA now offers the option in Metod to have the dishwasher fronts divided, so they appear as if the dishwasher has multiple drawers. Alternatively, you can install a continuous door as before. This can also be selected in the online planner, which will then display the desired front layout.
Additionally, I found out that Metod requires a special mechanism where the dishwasher fronts slide along rails attached to the dishwasher door. I think it works similarly to the sliding doors on refrigerators.
What isn’t clear to me yet is whether this special sliding mechanism is mandatory with Metod, or if you can still mount the front fixed directly to the dishwasher door as before. Does this have something to do with the different plinth height between Metod and Faktum?
If you want to attach multiple partial fronts to the dishwasher door, you need the Vaglig (20250663) product. This consists of two rails that hold the partial fronts together. But as far as I understand, this does not include the sliding mechanism itself.
For the sliding mechanism, you then need either Resonlig (50248348) or Behjälplig (50242426). The difference between these two seems to be that they fit different dishwasher models (Resonlig for Skinande, Rengöra, and LAGAN; Behjälplig for Hjälpsam). However, I have not yet figured out which one is needed for a non-IKEA dishwasher.
There is also Ersättare (00250664), which appears to be an installation solution for semi-integrated dishwashers. Since IKEA does not offer semi-integrated appliances in their range, Ersättare is probably designed specifically for non-IKEA models that you want to install in Metod. I have also looked at the installation instructions for Ersättare, but some things are still unclear to me:
As I understand it, the lower part of the front must be a partial front with a height of 20cm (8 inches), which is hinged in such a way that it flips open when the dishwasher door is opened. Does this mean that a continuous front is not possible with semi-integrated dishwashers???
Additionally, the instructions state that the upper partial front, also 20cm (8 inches) high, must be cut to size depending on the dishwasher’s trim height. I assume this would only apply to fronts without embossed patterns, because if, for example, I cut a Lidingö front (which has an embossed pattern) in the middle at 20cm (8 inches), I would be cutting through the design?
Since I want to install an existing dishwasher with a semi-integrated front in my new Metod kitchen with Lidingö/Bodbyn fronts, I am currently puzzled about how the installation should actually look.
Since Metod will be available in Austria from April 1st, I will definitely ask IKEA then.
Does anyone already know the answers to my questions?
Sektionschef
IKEA-Experte
8 Mar 2016 23:26
The cheapest Miele would still be too loud for me.
For occasional use, you wouldn't buy a separate dishwasher, so the only options are washing by hand or a temporary solution if the dishwasher doesn't fit under the countertop. Or simply choosing the right one for the future kitchen.
Modern white base kitchen cabinets with drawers in a kitchen.
HÄGGEBY
Door, white
MrsBing
9 Mar 2016 10:50
The machine fits under the countertop, my husband just bought the Neff at the Siemens shop.
mex
5 Apr 2016 23:00
After reading a bit here, we will probably buy the Siemens SX76P030EU. It is reasonably priced. But there is one thing I don't understand. The appliance is only 86.5 cm (34 inches) high. The IKEA cabinets are 88 cm (35 inches) high with the base. What about the 1.5 cm (0.6 inch) gap in between? If I attach my door to the top of the dishwasher, won’t the door be uneven at the top and bottom compared to the other fronts? Or do I simply need to have the dishwasher door overlap the top by 1.5 cm (0.6 inch)? How does it work so that all the kitchen fronts are the same height?
Addendum: I assume the dishwasher feet can be adjusted in height, right?
IKEA-Experte
5 Apr 2016 23:30
86.5 cm (34 inches) is just the minimum height. The feet are adjustable.
mex
22 Apr 2016 10:40
Does the Neff S72P69X0EU dishwasher fit easily into the Ikea kitchen without any modifications? I’ve checked the dimensions and it seems like it could fit. But before I place the order, I’d like to get a confirmation or advice from you experts here. Thanks.
IKEA-Experte
22 Apr 2016 14:21
Yes, as mentioned a few posts above, it fits.
