Hello
Has anyone here already looked into the installation options for dishwasher fronts in the new Metod kitchen system? I have spent some time researching this topic and would like to share my current findings with you:
As I understand it, IKEA now offers the option in Metod to have the dishwasher fronts divided, so they appear as if the dishwasher has multiple drawers. Alternatively, you can install a continuous door as before. This can also be selected in the online planner, which will then display the desired front layout.
Additionally, I found out that Metod requires a special mechanism where the dishwasher fronts slide along rails attached to the dishwasher door. I think it works similarly to the sliding doors on refrigerators.
What isn’t clear to me yet is whether this special sliding mechanism is mandatory with Metod, or if you can still mount the front fixed directly to the dishwasher door as before. Does this have something to do with the different plinth height between Metod and Faktum?
If you want to attach multiple partial fronts to the dishwasher door, you need the Vaglig (20250663) product. This consists of two rails that hold the partial fronts together. But as far as I understand, this does not include the sliding mechanism itself.
For the sliding mechanism, you then need either Resonlig (50248348) or Behjälplig (50242426). The difference between these two seems to be that they fit different dishwasher models (Resonlig for Skinande, Rengöra, and LAGAN; Behjälplig for Hjälpsam). However, I have not yet figured out which one is needed for a non-IKEA dishwasher.
There is also Ersättare (00250664), which appears to be an installation solution for semi-integrated dishwashers. Since IKEA does not offer semi-integrated appliances in their range, Ersättare is probably designed specifically for non-IKEA models that you want to install in Metod. I have also looked at the installation instructions for Ersättare, but some things are still unclear to me:
As I understand it, the lower part of the front must be a partial front with a height of 20cm (8 inches), which is hinged in such a way that it flips open when the dishwasher door is opened. Does this mean that a continuous front is not possible with semi-integrated dishwashers???
Additionally, the instructions state that the upper partial front, also 20cm (8 inches) high, must be cut to size depending on the dishwasher’s trim height. I assume this would only apply to fronts without embossed patterns, because if, for example, I cut a Lidingö front (which has an embossed pattern) in the middle at 20cm (8 inches), I would be cutting through the design?
Since I want to install an existing dishwasher with a semi-integrated front in my new Metod kitchen with Lidingö/Bodbyn fronts, I am currently puzzled about how the installation should actually look.
Since Metod will be available in Austria from April 1st, I will definitely ask IKEA then.
Does anyone already know the answers to my questions?
Sektionschef
Sektionschef
Juliette W17 Feb 2015 14:28Many thanks, Jelimi. This is already very informative and looks much better than the other picture (for which I have to rely on the photographer’s information).
IKEA-Experte17 Feb 2015 14:48Jelimi installed the machine at a total height of 90cm (35 inches) instead of 88cm (35 inches). Without having thought it through, maybe that is the difference between the two installations.
I just read through the thread to find an answer or solution. If I understand correctly, I can easily install the Bosch SBE65N00EU (XXL appliance with variolink hinge) in my Metod kitchen. I want to use a split front, connect it into a single front using flat bars or sheet metal, and mount it on the dishwasher according to the instructions. I would install an Ikea Blankett handle on top. Would this work?
IKEA-Experte4 Mar 2015 22:00It should all work this way, if necessary with a spacer under the front fasteners.
does anyone have a simple technical drawing of a front panel (without divisions) for the Skinande dishwasher? Specifically, dimensions showing where the drill holes need to be and where the handle should be mounted?
Basically, a replica of this one, without divisions (called "fronts"):
Product dimensions
Width: 60.0 cm (24 inches)
Height: 88.0 cm (35 inches)
Cabinet height: 80.0 cm (31.5 inches)
Thickness: 1.6 cm (0.6 inches)
Product dimensions
