ᐅ Dishwasher front panels
Created on: 26 Mar 2014 11:26
Sektionschef
Hello
Has anyone here already looked into the installation options for dishwasher fronts in the new Metod kitchen system? I have spent some time researching this topic and would like to share my current findings with you:
As I understand it, IKEA now offers the option in Metod to have the dishwasher fronts divided, so they appear as if the dishwasher has multiple drawers. Alternatively, you can install a continuous door as before. This can also be selected in the online planner, which will then display the desired front layout.
Additionally, I found out that Metod requires a special mechanism where the dishwasher fronts slide along rails attached to the dishwasher door. I think it works similarly to the sliding doors on refrigerators.
What isn’t clear to me yet is whether this special sliding mechanism is mandatory with Metod, or if you can still mount the front fixed directly to the dishwasher door as before. Does this have something to do with the different plinth height between Metod and Faktum?
If you want to attach multiple partial fronts to the dishwasher door, you need the Vaglig (20250663) product. This consists of two rails that hold the partial fronts together. But as far as I understand, this does not include the sliding mechanism itself.
For the sliding mechanism, you then need either Resonlig (50248348) or Behjälplig (50242426). The difference between these two seems to be that they fit different dishwasher models (Resonlig for Skinande, Rengöra, and LAGAN; Behjälplig for Hjälpsam). However, I have not yet figured out which one is needed for a non-IKEA dishwasher.
There is also Ersättare (00250664), which appears to be an installation solution for semi-integrated dishwashers. Since IKEA does not offer semi-integrated appliances in their range, Ersättare is probably designed specifically for non-IKEA models that you want to install in Metod. I have also looked at the installation instructions for Ersättare, but some things are still unclear to me:
As I understand it, the lower part of the front must be a partial front with a height of 20cm (8 inches), which is hinged in such a way that it flips open when the dishwasher door is opened. Does this mean that a continuous front is not possible with semi-integrated dishwashers???
Additionally, the instructions state that the upper partial front, also 20cm (8 inches) high, must be cut to size depending on the dishwasher’s trim height. I assume this would only apply to fronts without embossed patterns, because if, for example, I cut a Lidingö front (which has an embossed pattern) in the middle at 20cm (8 inches), I would be cutting through the design?
Since I want to install an existing dishwasher with a semi-integrated front in my new Metod kitchen with Lidingö/Bodbyn fronts, I am currently puzzled about how the installation should actually look.
Since Metod will be available in Austria from April 1st, I will definitely ask IKEA then.
Does anyone already know the answers to my questions?
Sektionschef
david_87
6 Dec 2016 12:03
It is installed and butts up against something, so you can open it up to a certain angle, and then it hits the lower part of the dishwasher... However, the installer has never heard of a Vario hinge.
Juliette W
6 Dec 2016 12:15
Hm, I don't want to offend your installer, but maybe something wasn’t done quite right? We have a different Siemens XXL with a Vario hinge, and it works perfectly fine without any issues.
david_87
6 Dec 2016 12:50
I’m wondering the same. Did you have to install the hinge separately? As far as I understand, he hasn’t fixed the front panel yet either, so it’s basically just attached, because he believes that about 3cm (1 inch) needs to be removed from the front.
How does it work exactly? When you open the dishwasher, does the front panel automatically move up a few centimeters (inches), or is it only pushed up once the front hits the dishwasher?
Thanks
IKEA-Experte
6 Dec 2016 14:33
Hello, the variable hinge is already integrated. The front panel might not move upward when opening because it is not properly attached to the bracket and is slipping.
Take a close look at the assembly instructions yourself. Installers often have a fear of reading the manual. Also, check the rating plate to confirm that the correct dishwasher was delivered.
[YouTube:26tsob8q]05GcAjuRS9M[/YouTube:26tsob8q]
david_87
6 Dec 2016 14:39
So far, I can say that the installers have not yet fixed the front in place; they have only attached it temporarily, since it was bumped during testing, as I mentioned. This way, I still have the chance to remove the front and shorten it. I need to take a closer look at it at home.
IKEA-Experte
6 Dec 2016 15:46
Just don’t cut anything off. If it doesn’t work out, we’ll figure out the problem somehow.
