ᐅ What to do if the Ikea Metod countertop doesn’t fit exactly?
Created on: 19 Nov 2018 08:42
Kai57
Kai57
19 Nov 2018 08:42
Hello everyone, I recently planned an IKEA Metod kitchen and ordered the countertop. Unfortunately, the countertop doesn’t fit exactly; it is about 5 mm (0.2 inches) too long on one side, and the back edge also doesn’t seem to be flush. I have checked the measurements several times, and they match the specifications from IKEA. Now I’m wondering: What can I do if the IKEA Metod countertop doesn’t fit perfectly? Are there any tips on how to professionally compensate for small discrepancies without having to replace the entire countertop? Which tools or materials would be suitable for this? I would prefer not to have to live with a rough cut or poor installation, as the kitchen otherwise looks really nice. Thanks for your help!
Laure57
19 Nov 2018 09:11
Hello Kai57, such fitting inaccuracies with IKEA Metod countertops are unfortunately quite common, especially with laminate or veneer surfaces. It is important that you first precisely determine where the countertop is too large and whether this is due to a measurement error or slight warping. Often, it helps to recheck the countertop directly against the wall and edges using a reliable wooden measuring tape, and if necessary, carefully trim it with a straightedge and a handsaw or laminate cutter. Alternatively, a router with an appropriate bit can be used to neatly round off the edge if you need to remove a few millimeters (fraction of an inch). Be sure to apply even pressure and feed it slowly to avoid fraying.
Germanro
19 Nov 2018 09:43
Mark the countertop and cut it with a handsaw or circular saw. Then smooth the edges with sandpaper or a rounding router bit. This way, you will achieve an exact fit.
Gregory
19 Nov 2018 10:05
The 5 mm (0.2 inch) overhang on the side can usually be easily removed with a cutoff saw or handheld circular saw. It is important to use a fine-toothed blade specifically designed for laminate or coated materials. Before cutting, the cut line should be accurately marked and covered with self-adhesive painter’s tape to prevent chipping. Afterwards, the cut edges should be smoothed with fine sandpaper (grit 120-180) and, if necessary, fitted with an edge protector. If the countertop at the back does not sit flush against the wall, moldings or silicone sealant can be used to visually conceal any gaps or unevenness.
Kai57
19 Nov 2018 11:12
Thank you for the quick responses and tips. I am already in the process of organizing the necessary tools. Just to be sure I understand correctly: Is it worth buying or renting a router tool for saving just a few millimeters (inches) of material waste? Or can I rely on sanding and adjustments with a handsaw and sandpaper? I ask because I have no experience with routers and am not sure whether they reduce or increase the risk of tear-out.
Laure57
19 Nov 2018 11:39
That is a valid question. A router is definitely more useful if you want not only to straighten the edge but also to create a nice rounding or chamfer at the same time. This results in a clean finish for the work surface and prevents the edge from fraying. If you are unsure about using a router or don’t have one readily available, you can also rely on a sharp handsaw blade and a lot of patience. In this case, make sure to use a fine-toothed blade suitable for laminate and then carefully smooth the edges with sandpaper. As a compromise, a rounding bit attachment for a jigsaw might also help.
