Hello everyone, I recently planned an IKEA Metod kitchen and ordered the countertop. Unfortunately, the countertop doesn’t fit exactly; it is about 5 mm (0.2 inches) too long on one side, and the back edge also doesn’t seem to be flush. I have checked the measurements several times, and they match the specifications from IKEA. Now I’m wondering: What can I do if the IKEA Metod countertop doesn’t fit perfectly? Are there any tips on how to professionally compensate for small discrepancies without having to replace the entire countertop? Which tools or materials would be suitable for this? I would prefer not to have to live with a rough cut or poor installation, as the kitchen otherwise looks really nice. Thanks for your help!
Here is a brief step-by-step recommendation:
- Measure the countertop precisely again and mark where the edges do not fit.
- Apply painter's tape on the cut edge to significantly reduce splintering while cutting.
- Use a fine-toothed saw, such as a laminate circular saw or a handsaw with very fine teeth.
- Saw with steady pressure and avoid pulling too hard to prevent splintering.
- Then smooth the cut edge with fine sandpaper.
- If the edge still looks very noticeable, edge banding or a matching trim strip can help.
- For rear edges that are not flush, use silicone sealant in a color matching the wall and countertop. This creates a neat and waterproof finish.
This way, you avoid rough cuts and achieve a professional result.
Thanks for your input from yesterday. Last night, I tried working on the board using a hand saw and masking tape. This helped prevent some tear-out, but the edge didn’t come out as clean as I had hoped. Since I’m now considering renting a router, I’m interested in how to properly use a round-over bit and whether you need to be particularly careful when routing to avoid removing too much material. Tips on handling a router with the Metod countertop would be helpful.
That sounds promising, Kai57. When using a roundover bit on a router, keep the following points in mind: - First, run along the edge slowly to avoid tearing the surface. - Adjust the cutting depth in several passes; it’s better to make multiple shallow cuts than one deep one. - Choose the right cutting tool depending on the countertop material, for example, a carbide bit for laminate. - Secure the workpiece firmly to prevent it from shifting during routing. - Use the router at a high speed with a stable guide fence. If you’re worried about splintering, you can apply masking tape over the cutting line before routing – this often helps. Good luck!
